Rebuilt engine start up
Engine-break-theory
You didn't say what the details on the trans are but if its a new auto before firing the engine add 6-7 quarts before the first start and after starting add as needed.
I run mine for a couple of minutes then shut it down to check for leaks. I always have the car up in the air on jack stands so things are easier to see.
As said above get it temp. Check coolant level. Change oil and filter. I get the fuel pressure checker from Oreilly's to check fuel pressure.
Still up in the air I run it shortly thru the gears auto and or manual trans.
Good luck.
