hp or boost on gen 3 rods.
I didn't follow the high rpm rule... but It was a super low compression deal with a cam that didn't make decent power till 5500 plus. Dished piston 5.3 with 317 heads/ls9 gaskets and ls9 cam. All the "wrong parts" according to some... Trending Topics
I didn't follow the high rpm rule... but It was a super low compression deal with a cam that didn't make decent power till 5500 plus. Dished piston 5.3 with 317 heads/ls9 gaskets and ls9 cam. All the "wrong parts" according to some...The Best V8 Stories One Small Block at Time
Engine dynos will spit out some super inflated numbers IMO. Or the real world numbers calculated by weight and trap are just under inflated... How ever you want to look at it.
Holdner made 910 on 10lbs with that gen3 6.0. You have to run closer to 20-25psi on a factory long block "cam only" motor to make 900ish hp in my experience. Unfortunately we don't get to see what any of Holdners "1000 hp" motors actually run in the 1/4. I think most would underwhelming...
Remember Freiburgers F-BOMB camaro? Dyno'd 1500hp at Westech engine dyno. Couldn't manage to get in the 8's with it. Trapping the same as my maybe 900chp setup at similar weights going 8.70... in an SBE 4.8 I'll add. So take the "1000+HP" westech dyno numbers with a gain of salt IMO.
