Camshaft “Dowel Pin”
Makes sense, I didn’t see the dowel at all when front cover removed, so you’d add dowel back inside cam, and just send it ? After retiming it!
Tap it back in the cam with a tiny dab of red loctite on it. Clean the pin and the hole with brake parts cleaner and a Q-Tip. Must be clean for loctite to bind. Re-install the bolts with a dab (tiny drop) of blue loctite. 22 ft lbs on your torque wrench. Are the threads on the cam bolts beat up, from running while loose?
The dowel must be in the oil pan, I’ve ordered a new oil pan as I planned to put this engine in a 1997 obs GMC Sierra and lower it, I will look for the dowel pin, the cam bolts didn’t look terrible, they do thread pretty smoothly and still tighten, so I’ll use them or possibly use new ones!
With the bolts loose, all the stress is on the pin. They are press fit, and hard as hell. My guess would be the hole in the cam is now oversized a bit.
You will know if you find the missing pin and try to put it back in. Cam gear hole may be wallowed out as well.
By all means use new bolts.
