Engine knock after torque converter install.
Old Feb 21, 2023 | 08:11 PM
Originally Posted by Kfxguy
bent rod.
This. I have a 5.3 in the shop right now that has a bent rod. It sounds just like this. Rod was bent just enough to make the skirt kiss the counterweight on the crank. Injector stuck open and partially filled the cylinder at shut down.
Old Feb 21, 2023 | 08:35 PM
Gene Cheeseman's Avatar
So the ROD
Is causing a knock.
I guess I'm too old to make up the terminology.
Old Feb 21, 2023 | 09:05 PM
Originally Posted by Gene Cheeseman
So the ROD
Is causing a knock.
No sir. The piston is hitting the crankshaft counterweight ever so slightly, due to the bent rod. The piston is causing the knock, but I guess it is the rods fault. Well no…it’s the injectors fault. What were we talking about again? 😜
Old Feb 22, 2023 | 12:14 AM
Papermachtech's Avatar
Originally Posted by 00pooterSS
Can you pull the converter bolts all the way out and push the converter back and then run the engine? It should slide back away from the flex plate 1/4 inch or more. If it won't, that's also a telling sign that it wasn't seated properly and is crushing the pump in the trans.
I vote for using your suggestion. It's a elimination game. Start at the beginning and work down.
Old Feb 23, 2023 | 01:28 PM
RonSSNova's Avatar
A buddies car made that same sound just after he hit the TB button at the starting line.
I would have sworn it was a rod bearing.
He drove it home, it turned out the flexplate was cracked around the crank bolts. Stock flexplate btw….which have no business on a 9 second car.
Old Feb 23, 2023 | 02:16 PM
MuhThugga's Avatar
Cracked flexplates and loose converter bolts will sound like rod knock. If this noise started after the torque converter was installed, I would be looking at the installation of the converter. Separate it from the flexplate (you don't have to pull the trans to do this), and fire the engine back up. Either the noise will remain or it will disappear, and then you will know whether the issue is with the engine or the transmission.
Old Feb 23, 2023 | 05:24 PM
Originally Posted by street_heat_z28
Unbolted tq converter from flexplate and sound still there.
Old Feb 23, 2023 | 07:40 PM
pdxmotorhead's Avatar
If you have grade 8 bolts holding the converter on, then the spacer material under the converter should be grade 8, those look like home depot imported galvanized washers.
their thickness consistency is questionable and they don't look like they are lining up so their hole is bigger than the bolt.
You should use hardened machinists washers that fit the bolts, and they can be bought in thicknesses so they don't need stacked. Yes they will cost 5 bucks each.
I get mine at a local precision fastener company.. (Think head bolt washers, aircraft suppliers... )
 Michael S. Palmer
Old Feb 23, 2023 | 08:10 PM
Kfxguy's Avatar
move used just regular washer before but I did buy a box of them to measure and get all the same thickness. They can/will vary greatly. This isn’t his problem tho.
Old Feb 23, 2023 | 08:54 PM
I was thinking converter is not aligning correctly to crank? Don't know why I didn't say that.. Sorry about that.. LOL
Like the end of the converter input could have angular runout?
Old Feb 23, 2023 | 09:01 PM
The impeller hub?
It wouldn't still knock with the converter unbolted as the OP has stated that he's done.
Old Feb 24, 2023 | 09:09 AM
  #32
grinder11's Avatar
WOW, hardened washers are $5 EACH??!!!! WHEW!!!
Old Feb 24, 2023 | 10:27 AM
  #33
LS299S10's Avatar
Rods do not knock unless the bearing has spun. They are the same.
A friend of mine didn't clean the crank after machining a while ago. It had a knock, one of the bearings had around .010 clearance presumably from garbage washing out of the journals. Replaced the bearings with it in the truck and the problem went away. No spun bearings.
Old Feb 24, 2023 | 05:26 PM
  #34
Kfxguy's Avatar
The fast paced knock its making is why i think its a bent rod and the skirt it contacting the counter weight. Usually is its a rod bearing knocking like that, it won't knock very bad at idle or revving (unless its really realy bad, and in that case, the thing should have seized by now) but when you put it under a load, it'll knock even more. With a bent rod OR a top ring land busted, the intensity will not usually change under load. Yes a busted top ring land will sound like this too. I know from personal experience.
Old Feb 24, 2023 | 05:35 PM
  #35
Kfxguy's Avatar
Found a video of mine when I broke the top ring land on the piston. No idea why it was knocking because the part of the piston missing was completely gone.
Old Feb 25, 2023 | 11:37 AM
  #36
RonSSNova's Avatar
It's not SBE, it has good parts in it. But I suppose a rod could still get bent.
When I look at that crusty rusted flexplate I just get suspicious.
Fun to guess though, which is what we all are doing. :-)
Have to see what he finds out!
Ron
Old Feb 25, 2023 | 11:41 AM
  #37
Maybe it's a bleeder screw imbedded in the piston.
Old Feb 25, 2023 | 01:47 PM
  #38
LS1Formulation's Avatar
Yeah, OP needs to update this thread!
Old Feb 26, 2023 | 07:24 AM
  #39
street_heat_z28's Avatar
Sorry guys been busy with the kids sports and not much garage time. I got the trans out. Flexplate looked fine. Same noise when running. Pulling the heads this week to check valve train. There was also a different tune put in the car at the time of the converter install. Could be a burnt piston. I'll update as I can. Thanks for the info.
Old Feb 26, 2023 | 10:53 AM
  #40
Some slack, guys.... it's only been a week... but fear not... he's BAAAACK!
