Prc 225 heads running on factory tune?!?
Old 02-22-2023, 03:18 PM
88_thirdgen's Avatar
Default Prc 225 heads running on factory tune?!?
First off let me start by saying, yes im aware that the full potential of any mods like heads, cam etc benefit highly from a custom tune and is needed for the car to run properly, hell bone stock a car benefits from a tune. This is my scenerio though and i need some input hopefully someone has good advice.
The car in question is a 02 trans am ws6, ls1, prc 225 as cast heads, torquer v2 cam and a fast 92/92, lt headers and dyno tuned, 475 rwhp.
My issue now is i live in California
And before anyone says just move out of California, its easier said than done and yes i know California smog laws are ridiculous.
Which brings me to this, being that my car is a 2002 it will not pass smog for obvious reasons visually it wont and now they check for factory tunes which wont pass. To pass smog on a 2000+ vehicle in California all they are checking is monior readiness and visual inspection, so no they do not run it on the dyno for the sniffer. So now ive come to the realization that i dont want to deal with it anymore and just conform go back to stock or stockish.
Ive been throwing the idea around of doing a "stealth build" meaning putting back my stock exhaust manifolds, cats, air injection, factory tune, but leaving my prc heads on, putting a ls6 cam or comp cams even has a carb approved cam and sanding down my fast 92 intake manifold smooth and painting all black and putting the stock tb.
Now the real question in mind how will the car run on a factory tune with said mods??
-heads prc 225, 62 cc combustion chambers, 2.065 intake valves and 1.600 exhaust. Pac 660 dual valve springs
-The cam im looking into is a carb approved cam which is a 210/218 118 lsa intake/exhaust duration 270.
- fast 92mm intake
- stock exhaust
- stock tune
There is also a set of afr heads that are carb approved in which they claim you need no tune to run them and theyare smog legal but are like 3k.
the real issue here is the tune, it has to be a factory tune.
all that i need is for it to visually look factory which i think can be achieved pretty easily, have all the emissions monitors completed and have a factory tune on the pcm and id be golden. Any input helps alot! If not id just go back full 100% stock 😒
Old 02-23-2023, 04:45 AM
LS1Tech Sponsor
Tony @ Mamo Motorsports's Avatar
Here is the deal.....you just have to pass the test with the OEM tune.....don't even think you get the sniffer test but it has to idle and run on the stock tune (and not throw a code)
That mostly means two things....OEM injectors (that is what the stock tune is designed for) and a cam small enough to idle at the stock tune's idle speed target.
Your current cam wont do that.....none of the other stuff matters as much if the guy looking over the car is a friendly. But it cant throw a check engine code when its plugged in and a big cam wont idle well at 600 - 650 RPM
You have to reduce the overlap.....a cam in the low 220's on like a 114 LSA would probably work.
And like I said....OEM injectors or the fueling will be way off
Its a suckfest in CA with this emissions crap....thankfully its two years apart so you get a chance to play for a bit before having to meet the smog man again
You could always install an OE cam for the smog test and swap it a week later. Its alot of work but you get to play with the car properly modded two years before dealing with it again (or moving!! )
-Tony
__________________
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
The following users liked this post:
grubinski (02-24-2023)
Old 02-23-2023, 07:52 AM
grinder11's Avatar
Hi, Tony. IDK if you'll agree, but I think with this California situation, wouldn't the OP, and other California residents with mods also benefit from a handheld tuner? That way, you could store the stock tune, and could also store the mod tune?
Old 02-23-2023, 10:09 AM
RonSSNova's Avatar
Like Tony said, you can’t just stick a stock tune back in and hope a modified car will even run much less pass the emissions test.
G Atsma (02-23-2023)
Old 02-23-2023, 10:31 AM
grinder11's Avatar
Oh, I completely agree. The other side of the coin is you can't run a stock tune if the OP goes to the trouble of changing back to the performance cam. Just thought it might save him paying for another tune for the performance cam. Personally, and I know moving is nobody's idea of fun, but I'd get the Hell outta there with the performance cam and tune, so I could leave California ASAP!!! People in California may be surprised how far their net $$$$$$ from the sale of their house will go in a different state. Changing cams, pipes, tunes, and whatever else is needed every 2 years would be all the incentive I'd need...
Old 02-23-2023, 11:49 AM
ddnspider's Avatar
Received 1,740 Likes on 1,299 Posts
How are they checking for the stock tune?
Old 02-23-2023, 12:06 PM
Received 3,089 Likes on 2,405 Posts
By plugging into the OBDII port and checking the bitsum in the tune. ANY kind of change is a callout.
All that is involved to smog a 96-up car is to plug into the OBDII port and do a visual for illicit aftermarket parts like non-exempt headers and/or cold air intakes.
88_thirdgen (02-23-2023)
Old 02-23-2023, 01:07 PM
ddnspider's Avatar
I tune and understand a checksum and flashing/reading a vehicle. I'm asking specifically the level of detail the testing site is going to. Does that mean they have the OEM calibrations for every vehicle ever made that is under the smog requirement? Or do they pull the stock tune from the vehicle the first time it's been smogged. I.E. why can't the "stock tune" be the 475whp dyno tuned version of the tune file. Then in 2 years it will be the same file.
Old 02-23-2023, 01:24 PM
RonSSNova's Avatar
They have the stock tune file info. Even tune files covered by TSB’s. The car manufacturers provided that info to CA.
In order to catch the small percentage of people who modify their cars.
The discussion about all of this started a couple of years ago.
The following 2 users liked this post by RonSSNova:
88_thirdgen (02-23-2023), G Atsma (02-23-2023)
Old 02-23-2023, 01:25 PM
-Tony
Hi Tony, like i mentioned in my original post i currently have a torquer v2 cam, i have no intention on running that cam on a factory tune and hoping it will pass smog on the factory toune ,id be shooting myself in the foot, its a 112 lsa it chops id get state reffed right away 😅 , but what i am thinking of doing is ditching the torquer v2 in place of a ls6 cam or the carb legal comp cams which is a 210/218 on a 118 lsa which both cams dont require a tune AND ,will idle factory, along side my prc heads and fast 92 and this will be with factory injectors, cats, exhaust manifolds all emissions connected and running monitors.
My overall question is this, will the car compensate fuel trims for said mods, ls6 cam and or the 210 216 comps cam, the 62 cc prc heads and the fast 92mm intake, running everything else bone stock?
Old 02-23-2023, 01:32 PM
RonSSNova's Avatar
Between STFT and LTFT there is a lot of trim range available. On the order of 50%.
Old 02-23-2023, 01:33 PM
This is exactly what i was thinking of doing!! BUT there is down side. That being you cant mod the car past a certain point meaning it has to be modified to a point at a fine line where it will still run and operate on a factory tune with the mods without triggering a c.e.l and then switch over to custome tune designed to bring out full potential with a diablosport tuner or something along the lines.
Old 02-23-2023, 01:40 PM
ddnspider's Avatar
That is brutal, so they're using a device like HPT or EFI Live or a Tech 2 to compare.....the irony would be excellent if they used a tuner suite like HPT or EFI to confirm that someone DIDN'T tune their cars.
Old 02-23-2023, 02:03 PM
The California air resource board has gone as far as soon requiring smog stations to install cameras in which they can remotely watch the smog techs doing the smogs 😬. This is why i dont want to deal with having an overly modified car but i still want more than stock , im looking for a long term solution and it seems like a very mild cam with other supporting mods that visually wont throw a red flag and that its capable of running on factory tune. Its just a matter of time where there will be less and less friendlies to smog and people have to bite the bullet and revert everything back to stock. I dont want my ws6 to end up a barn find show in the future because it was parked unregistered for the last 30 years lol
Old 02-23-2023, 02:41 PM
ddnspider's Avatar
Are antiques included or anything that has cats and O2s OEM?
Old 02-23-2023, 02:59 PM
In Cali, nothing before 1975 MY is tested. Between then and 1996 it's sniff and visual. After that it's OBDII plugin and visual.
I'm going to bring up something I posted about before-
Comp has a series of 50 state legal LS cams for Gen III and IV LS engines. Some for AFM/DOD and VVT.
The spec for Gen III is 210/218, .570/.541, 118 LSA. No tuning necessary is claimed, nor is it allowed in Cali.
I would like to know how a guy pulling out his stock (191/190, .457/.466 114 LSA) 5.3 cam is NOT needing a tune for a cam that adds 19 intake degrees.
I don't see how it will be even close to running right.
Old 02-23-2023, 03:16 PM
YES!! That is exactly my question here.. yet comp cams got the cam approved for use in California which in itself is not an easy task. Yet they claim it needs no tune to operate properly , which is in line with the requirements to pass without changing the factory tune. There is even a set of AFR carb approved cylinders heads in which they also claim need no tunning to run them and they have eo carb# and everything to pass.
So theoretically you can build your car in California heads and cam and but running on OEM tune and be 100% compliant. BUT how will the car really run?!
Old 02-23-2023, 03:55 PM
To anyone who has such a build, we are awaiting your honest answer.... unless Richard Holdener steps up....
Old 02-23-2023, 04:07 PM
Going on the premise that going with a stock tune IS possible or even desirable with this Comp cam, I wonder which aspect of the cam spec makes this possible.
The duration and lift seem pretty middle of the road.
210/218 is only 2 degrees intake away from the old faithful 212/218 grinds. So it can't really be that.
What DOES set it apart is the relatively very wide 118 LSA.
This smoothes the idle and allows for a -22 degree overlap, but a fairly late 43 deg. ABDC intake valve closing.
That's still a lot more overlap than the stock cam's -37.5, but i guess the stock tune still thinks it's OK....
Old 02-23-2023, 04:52 PM
Lets say that the comp cam is factory tune friendly and wont cause any issues, judging by the cam specs alone and by the fact comp cams is being granted permission to sell it and use in California it will be fine , hell even undetectable because it will idle stock and there will be tunning involved, its not like they are going to disassemble your engine to check. BUT how would the car run , say you add heads and intake? Would this cause a lean condition? Being that there is more airflow introduced into the combustion chambers?
Quick Reply: Prc 225 heads running on factory tune?!?
