Ls1 Piston Ring gap
Old Feb 23, 2023 | 02:56 PM
red79phoenix's Avatar
Default Ls1 Piston Ring gap
1999 ls1 .023-0.24 on top rings, .017-.019 on the second ring, and oil rings .026-.031. Build is stock, may see boost but probably not. What should I be looking for as far as ring gap on each ring including oil rings?
Old Feb 23, 2023 | 11:01 PM
Second ring must have larger gap than top ring or gases can’t escape. It will cause ring flutter and rings won’t seal. With .023-.024 top, you need to shoot for .026-.028 second ring. Oil rings are fine. Are you 100% sure that you don’t have top ring and second ring mixed up?
Old Feb 24, 2023 | 10:43 AM
The ring brand is Hastings and they came individually packaged marked 1st/2nd/3rd. The second ring also has a dot - which is consistent with a “which ring is the top ring” video they have. So I am 99% sure they are correct.
So I guess I need to file the second ring down to .026-.028?
Seems like these first ring gaps are screaming to be boosted….
Old Feb 24, 2023 | 08:43 PM
rednari2's Avatar
The rings are ridiculous today. I went through checking two sets of Hastings iron rings and each had a top gap of around .028. While I did not measure the second ring, the gap appeared larger. I talked to the machine shop about the size of the rings and he said all Hastings rings had larger gaps than the OE .015, and not worry about it. So, I guess they're all gaped for boost and nitrous.
