Distance from coil bind help
Old Apr 24, 2023 | 10:53 AM
Lq4c10's Avatar
Default Distance from coil bind help
I have BTR dual 660 valve springs and I measured my spring install height at 1.77
BTR says coil bind is 1.070 and my cam is 232/234 .600/.600
does this work out to 0.107 from coil bind and is that ok?
Old Apr 24, 2023 | 08:17 PM
Jake Wade's Avatar
I get .100 from coil bind from your numbers. That will work for you as long as retainer to seal clearance is good.
Old Apr 24, 2023 | 08:40 PM
Lq4c10's Avatar
sorry, should have been 1.777 install height. Any need to shim?
Old Apr 25, 2023 | 05:20 AM
Jake Wade's Avatar
If you are looking for a certain seat pressure.
What are the advertised spring installed height and rate numbers?
Old Apr 25, 2023 | 06:22 AM
Lq4c10's Avatar
what seat pressure should I be looking for?Spring specs are as follows:
•155 lbs @ 1.780"
•380 lbs @ 1.180"
•400 lbs @ 1.130"
•Coil bind @ 1.070"
Old Apr 25, 2023 | 09:56 AM
Jake Wade's Avatar
Not sure exactly what you are doing, what lifters, what camshaft core material.
The seat/open pressures look good for a hydraulic roller hot street deal.
I would run it as is. No shimming.
Old Apr 25, 2023 | 10:43 AM
Lq4c10's Avatar
btr ls7 lifters.
Everything I can find it pointing to good
appreciate you help, first timer here
Old Apr 25, 2023 | 08:52 PM
I agree with JW. No shimming needed with that cam, as it’s not gonna see the RPM needed for shimming those springs.
