Gen 4 internals into gen 3
Old May 16, 2023 | 10:56 AM
Bbknucks's Avatar
Default Gen 4 internals into gen 3
I have a lm7 I am building for a swap and planning on boosting.
I may have just acquired a lc9 with a cracked block due to freezing. Otherwise runs great
I was wondering if it would be worth it to slap the pistons and rods out of the gen 4 into the gen 3. Will put new bearings and rings and hone the block.
also maybe swap the 706s for the 799s
Thoughts?
Old May 16, 2023 | 11:18 AM
The Gen IV pistons are flat tops, so yeah, use the 799's to keep compression sane.
Old May 16, 2023 | 11:27 AM
Bbknucks's Avatar
So I should drop the gen 4 pistons and rods in?
Old May 16, 2023 | 11:29 AM
If they're in good shape, I don't see why not.
Don't forget to switch the reluctor wheels to the 24x from the old crank.
Old May 16, 2023 | 12:08 PM
Bbknucks's Avatar
I was planning on putting those pistons on the other crank but if swapping the reluctor isn't too bad then ill do that
Old May 16, 2023 | 01:02 PM
Actually the cranks should be the same though I'm not positive about that.
Old May 17, 2023 | 03:32 PM
Bbknucks's Avatar
I'm just gonna do rings and bearings on the 3 crank with the 4 rods and pistons and throw some boost at it and party
Old May 17, 2023 | 04:01 PM
1FastBrick's Avatar
The Gen 4 stuff is heavier. Use the Gen 4 crank and swap the reluctor if you have too since its already balanced for the added weight.
