Gen 3 lq4 high rev
Old May 21, 2023 | 10:26 PM
pwilliams's Avatar
Default Gen 3 lq4 high rev
Lq4 on start up it revs up to 4000 rpms then drops to like 1500 then revs right back to 4000 over and over like someone it smashing the gas and letting off have All sensors connected and vacuum lines it’s an aftermarket intake manifold sheet metal from jegs and a sloppy stage 2 cam
pcm is tuned and bought with the engine iacv too and set screw on throttle body is damn near all the way down (I plan on using a 4l80e and it’s my first ls swap so I’m not sure if not having the transmission connected and the pcm not being able to read what gear the trans is in and no vss or nss or tcc could mess with it) anyone know!
Old May 21, 2023 | 10:53 PM
Which throttle body are you using?
Old May 22, 2023 | 12:53 AM
pwilliams's Avatar
I’m using the jegs ls 102mm throttle body part number 555-14526
Old May 22, 2023 | 12:56 AM
DBW or DBC?
Old May 22, 2023 | 12:59 AM
pwilliams's Avatar
I’m not sure but the guy I got the engine from I paid him to put it all on and he told me what to buy so I’d assume he would know but I can’t ask him at the moment a little late where I’m at
Old May 22, 2023 | 06:48 AM
Kjduvall's Avatar
i bet that intake manifold is leaking around the intake flanges / cyl head area really bad.
Old May 22, 2023 | 09:22 AM
You don't know whether your engine is drive by wire (electrical) or drive by cable (direct pull by cable)???
You need to learn your own car a lot better.... don't rely on others for info on YOUR car....
Old May 22, 2023 | 03:03 PM
Old Buzzard's Avatar
Wink Yep
I'm in with that suggestion. Imported and junk.
Old May 22, 2023 | 06:12 PM
If the TB has a adjustable set screw for idle control (which drives me crazy…sucks to tune) it is a DBC TB. DBW TB’s don’t have this feature. OP mentioned in first post it has the set screw.
Old May 22, 2023 | 07:01 PM
01CamaroSSTx's Avatar
That TB is DBC
Old May 30, 2023 | 03:06 PM
B4CMaro's Avatar
Smoke machine. Find the vacuum leak
