Lq4 - no oil on dipstick after oil change
it calls for 6qts and i put 7.5 qts in it. No oil on the floor, correct dipstick length, factory oil pan. At this point is doesnt matter because i figure it out when i rebuild the engine
I have a feeling that with the thinner oils being used these days, it just wasn't readily visible on the stick.
With a pan filled to over-spec with oil, and matching pan and stick, the above can be the only logical explanation.
The end of your dipstick hasnt broken off?
Has the dipstick tube been pulled out of its hole?
Your going to have to get under the truck and make sure .
Id be getting some small gauge wire a little longer than dipstick length and slide tht in, make it a lot longer and slide al the way.
You are pouring the oil into the top of the valve cover?
The following users liked this post:
G Atsma (07-10-2023)
G Atsma (07-12-2023)
![Talking](https://ls1tech.com/forums/images/icons/icon10.gif)
![](https://cimg2.ibsrv.net/gimg/ls1tech.com-vbulletin/151x151/bong_5757998195d520089cf35ae99ef84051b462d292.jpg)
The following 2 users liked this post by Old Buzzard:
dixiebandit69 (07-12-2023), G Atsma (07-12-2023)
Rick Dorion (07-12-2023)
Old Buzzard (07-18-2023)
#33
#34
Old Buzzard (07-26-2023)
G Atsma (07-26-2023)
#36
#37
This guy needs to start using Uber and forget cars.....
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#38
Sorry for the delay on this response. Yes there was a hole on the side of the tube and it tucked behind the exhaust manifold so i never seen it poke out until i started to pull the manifold off.
The following 2 users liked this post by Itsjustifiable:
G Atsma (01-14-2024), Old Buzzard (01-14-2024)
#39
I once got a huge surprise on a dipstick issue. As in I forgot to install it! Remembered everything else, though. This is what happens when you work too late and too long on something and start getting tired. BTW....You would not believe how much oil came out of that dipstick tube hole in the 4 or 5 seconds it took before the smoke was visible, and the "Oh ****" moment set in!!!!
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
The following 2 users liked this post by grinder11:
G Atsma (01-15-2024), Old Buzzard (01-16-2024)
#40
I once got a huge surprise on a dipstick issue. As in I forgot to install it! Remembered everything else, though. This is what happens when you work too late and too long on something and start getting tired. BTW....You would not believe how much oil came out of that dipstick tube hole in the 4 or 5 seconds it took before the smoke was visible, and the "Oh ****" moment set in!!!!![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
G Atsma (01-16-2024)
