Building a new ca build LM4
Do you happen to know the stock cam specs of a lm4. I thought about putting a bigger throttle body in it with intake and exhaust and tune till I build my motor.
The LM4 cam is the same as the LM7- 191/190, .457/.466, 114 LSA
Having said all that, if you can find a LQ9/early LQ4 cam (196/201, /467/.479, 116 LSA), it CAN be used without retuning. NOT optimum, but it will still show improvement you can feel.
The stock 78mm throttle body is all the 5.3 needs. Going bigger does nothing.
The stock truck intake is actually pretty good. Only a TBSS intake would really improve it, and not by very much.
Do NOT get a short runner sheet metal intake. They lose power all the way to 5K RPM.
