Piston identification
Old Dec 21, 2023 | 11:55 AM
Sen7's Avatar
Default Piston identification
Piston identification, can anyone help me identify the make of this LS2 piston please.
Can anyone identify the make of this LS2 piston please?
Only other markings on it are no1 and .50 stamped on it.
Old Dec 21, 2023 | 02:52 PM
slowride's Avatar
Looks like an aftermarket 0.020" piston which is 0.50mm over or close.
Old Dec 21, 2023 | 07:51 PM
1FastBrick's Avatar
Pull it out of the block. That might be a UEM Silvolite.
Old Dec 22, 2023 | 03:00 AM
Sen7's Avatar
It’s out the block and this is the only marking on it, I can’t relate it to any manufacturer
Old Dec 22, 2023 | 05:57 AM
1FastBrick's Avatar
Can you post a picture of what the out side of the piston looks like. I would like to see the coating and the ring lands.
Each manufacturer does it differently and it may help Identify it.
Old Dec 22, 2023 | 09:16 AM
Sen7's Avatar
Old Dec 22, 2023 | 10:38 AM
1FastBrick's Avatar
Well it's not a Silvolite, Speed pro, or Moresa.
The Skirt looks like an EngineTech P5041
Old Dec 23, 2023 | 09:51 AM
slowride's Avatar
Any issues with it or just trying to figure out what you had?
Old Dec 23, 2023 | 10:10 AM
Sen7's Avatar
Piston broke away on side by top ring. Trying to identify it. It measures 4.011”( in the correct place with calibrated equipment) but the bore measures 4.017. Neither makes sense!
Old Dec 23, 2023 | 10:51 AM
slowride's Avatar
So piston is very small for the listed size and the bore has way too much clearance for a OE replacement piston. Curious what the engine combo was?
