Need step by step for engine removal
Old Jul 26, 2004 | 10:26 PM
Cerebrex's Avatar
Default Need step by step for engine removal
Can someone please help me here? I'm dropping from the bottom by hoisting the car up on an engine hoist. Can someone tell me all the steps I will need to complete this project? Any help would be GREATLY appreciated. GREATLY!!!!
Thanks a lot for the help!!!
Old Jul 28, 2004 | 08:53 AM
Cerebrex's Avatar
can someone please help?
Old Jul 28, 2004 | 09:58 AM
crainholio's Avatar
Let's see...go flog the car, or sit here and type up my Helms...I'll get back to ya on that...
Old Jul 28, 2004 | 10:57 AM
Inspector12's Avatar
TT-TECH Veteran
PM'd you.
Old Jul 28, 2004 | 12:35 PM
Cerebrex's Avatar
not being done until saturday because it's in a different state than me
Old Jul 28, 2004 | 02:34 PM
Broken041's Avatar
a) Disconnect Negative battery terminal
b) Support Motor via hoist
c) Unbolt Transmission
d) Remove engine
Sorry, could not resist.
Old Jul 28, 2004 | 11:01 PM
Cerebrex's Avatar
yeah good try.. I was talking more along the lines of what i need to disconnect and such.
Old Jul 29, 2004 | 12:07 AM
TNormZ28's Avatar
It would take way too long to explain what to disconnect before dropping the motor and tranny out together. Driveshaft, disconnect torque arm, manifolds from y-pipe, tranny crossbrace. Move to motor up top. Remove PCM lay wiring harness on motor work your way around from passenger to driver disconnecting anything that goes to the motor, coolant lines, and not to forget brake lines, fuel lines, and there is a pesky little harness for the brake lines on the engine side of the driver side wheel well. Include pulling brake booster, unbolting the brake master cylinder and pulling up and laying it on your cowel. Then remove the strut bolts, and the 3 bolts on each side of the cradle from underneath. Start lowering the motor and tranny out slowly watching for anything catching. Whatever catches remove it, disconnect it or move it out of the way. That in an extremely short explaination is the engine and tranny drop out. I've done 3 or 4 of them, but not on my own. Get a couple of buddies to help out.
Old Jul 29, 2004 | 01:10 AM
Cerebrex's Avatar
take to long? you just did it! thanks bro!!!
