Should I use a timing chain damper
Old Aug 23, 2024 | 08:29 PM
Rich-L79's Avatar
You can buy the one I have for less and it is exactly the same thing. FWTW
Old Aug 23, 2024 | 09:15 PM
Originally Posted by Guy with a Chevy
So I can get away with just running the dampener in the middle without the outside tensioner? Damn tensioners break on me most times when I try to re install the tensioner assembly retainer pin to hold i in place!
You don't use both. Use the block. ONLY.
Old Aug 24, 2024 | 10:21 AM
91 Z28's Avatar
Did all LQ4 blocks have those mounting provisions?? I'm like 99.99% sure my 04 block didn't have them. The machine shop wanted to install one but it just wasn't there
Old Aug 24, 2024 | 10:42 AM
RB04Av's Avatar
Pretty sure they don't.
My 06 LQ9 block, which is the same as the LQ4 one, didn't have them. Maybe some do, like the OP's does, butt def not all.
They're SSSSSOOOOOOPER EEEEEEEEEEEZZZZZZZZZZZZZY to add. I did it with a hand drill, using the damper itself as a template.
Old Aug 24, 2024 | 10:44 AM
91 Z28's Avatar
I figured as much. Too little too late for me. I'm not about to open things up just to install a dampener. It's been running perfect without one the whole time so it'll be good until I either have a catastrophic failure or build a different engine whichever comes first
Old Aug 24, 2024 | 11:25 AM
66OldsLS's Avatar
summit or icy has an adapter that goes onto the cam plate I think and you bolt the dampener to that instead of having to drill holes for one. Makes it easier.
Old Aug 24, 2024 | 11:36 AM
91 Z28's Avatar
That's fun! I wish I knew things like that existed a few years ago
Old Aug 24, 2024 | 11:58 AM
66OldsLS's Avatar
Old Aug 24, 2024 | 12:23 PM
91 Z28's Avatar
Awesome thanks for that! I'm planning on doing lifters in the spring so maybe I'll do the damper as well
