Oil pressure
Edit--- GEN III 5.3 LM7. 2003 Tahoe motor swapped into my 2005 chevy colorado. In case that is needed.
…edit…Welcome to LS1Tech!
Why: near impossible to stop. Would require 24/365 human intervention and some means of detecting an AI in real time. I would hope that the forum mgmt deletes these things after a few days and it becomes obvious that it's not a real person. They're generally REAL eeeeeeezzzzy to spot; nearly always totally dart-board-level random first & last names, in CamelCase format, half the time of a gender that doesn't match the forum's predominant users. Like, a female userID with 2 plainly different ethnicities or a first name that nobody has called their kid for 75 years, on this forum, posting inane babble about "the update"; always with no actual mention of the actual topic and no actual contribution whatsoever, even a negative one.
Why do they do it: that, to me, is the mystery. I'm guessing that there are some forums that expose e-mail addresses and whatnot, and the pervs and scammers are hoping to land on one such.
The filter shouldn't cause more than acoupla pounds of pressure drop, in any case. It even has a bypass valve inside that opens when the pressure drop across it exceeds some amount indicating that it's plugged up and doing more harm than good. Usually something in the 5 - 7 psi kinda range in most filters.
