help with change of compression effects
Old Dec 27, 2024 | 01:04 PM
learning101's Avatar
Default help with change of compression effects
Did the head and piston change on my 5.3 put flat top pistons on with 799 heads cut .030 off deck so I went from stock 9.5 to 10.5 could I still use regular gas 89 octane. and will this effect the computer?
Old Dec 27, 2024 | 01:47 PM
If it's 89 octane you should still be OK. Have you run it yet? If so, and no knocking, keep cruisin'!
Old Dec 27, 2024 | 04:57 PM
the_merv's Avatar
Don't know how you think it will Affect the computer. Stock tune it will run all day might get labor knock in some of the part throttle range, it's a matter of where the timing is.
Old Dec 27, 2024 | 06:02 PM
Lxjoshxl's Avatar
Wouldn’t hurt to get a datalog and see if you’re getting any knock retardant jumping up. I’ve learned the stock tune file is pretty safe overall but you’ll be losing power if it’s just pulling a ton of timing?
Old Jan 6, 2025 | 06:40 AM
Old Buzzard's Avatar
And, what do the plugs look like?
Old Jan 7, 2025 | 08:16 AM
grubinski's Avatar
.030” out of the hole? Sure you’ll have enough quench?
Old Jan 7, 2025 | 10:01 AM
had trouble starting it found out stock pushrods are too long and left my valves open so i ordered .375 and .350 push rods with taking .030 off the head so we will see o ordered a push rod checker just in case
