Looking for cam recommendations
That cam didn't come alive until almost 4000 RPM, so if you don't want to rev to 7k it probably makes sense to go a little smaller. Something like 228/228 @ 110+4 would have about the same overlap (same driveability) and 4 degrees earlier intake valve closing, which should make the power come on earlier.
Also running terminator x max if that matters.
For reference I made 400rwhp with a LS1/t56, un ported 243 heads, Fast 92mm intake, 1 7/8 mid length headers with a 224/230 .581/.591 112lsa cam. On another LS1/4l60e build I made 435rwhp with a fast 92mm intake, ported 243 heads, 1 7/8 LT headers with a 228/232 112lsa .625 lift cam.
I would stay a little conservative with cam choice because a 79 monte is a heavy car, you want some low end torque to keep the car fun to drive on the street.
If you were to change, i would suggest flowtech Induction's streetsweeper HT. 228/232, .612, .600, 111+3. It's a monster torque cam with power pretty much everywhere.
221/241, .624/.636, 112LSA. Brian says it'll drive like a stocker. It has a little more overlap than I want (7º) which is why I'm still leaning towards the Power Max+ cam (-3º overlap). I want something quiet for my build: LS1 with 862 heads with the bigger valves, LS6 intake, PnP stock TB, going in a volvo 240 wagon. I think ever 350rwhp through my 4L60 would be great!
I was also debating on the SUM-8715 "ghost cam" (which I think is the same as their stage 1 turbo cam): 222/233, .600/.575, 115 +3 (-2.5º overlap). It seems much more than low 220's on intake duration on a 5.7L gives too much usable power down low away in exchange for gains way up high - not ideal for a DD street car IMO.
From what I have seen of the ghost cam before and after dynos, it maintains torque down low and then gains up high. The 8720 on the other hand should gain everywhere vs stock and out torque the 8715 but have a little less hp at the top. 8720 is a great improvement vs ls6 IMO and better than a 220/222.
