New Engine Antifreeze Recommendation Needed
What is the best antifreeze for a "new" engine. I had good luck with the OEM Dexcool, however, I see that there is a component called 2-EHA that can cause problems.
Anyone use PEAK Titanium in an LS?
Can you tell I'm looking to replace my coolant with something cooler?
On the topic of removing heat from the chamber, yet somewhat off camber here…keeping heat IN the chamber EFFICIENTLY and PURPOSELY is the goal of modern endurance builders and coatings are becoming more and more exotic in this area. Coated valves, chambers, domes, rings, are helping make advances in power by effectively controlling thermal energy.
Edit*
So I was thinking about this and I think I answered my own question because I realized when I make runs that aren't as aggressive and I'm spending more time at part throttle, I'm using the extra advance and the engine doesn't build added heat, It's only on The harder it runs where I'm spending the most time at wot that the heat gets concerning. So it's the timing under load then that needs addressed?
