Having hard time finding pistons
I found out that pistons in the engine are no longer being manufactured, neither rings for them.
Piston specs: Bore size: 3.910”, Compression Height: 1.105”, Crown Volume: 6cc (dish), Pin Diameter: 0.927”, Rings: 1.5, 1.5, 3.0mm.
I want to use this crank (3.9" stroke) and connecting rods (6.125", 0.927" pin) with the iron block. I'm able to bore the block to any size, hopefully something between 3.800" to 3.905".
Compression ratio needed is around 9.7:1. This is boosted car and held up with these parts for 20 years...
I thought pistons will be a piece of cake but 3.800" bore with 1.105 (up to 1.115) CH together with -2 to -5 cc dish seem unavailable. The same gose with larger bores, I'm not able to find candidates.
Please guide me to a good source of pistons.
EDIT: Some more specs: I measured head chambers to be 68 cc. The reason for iron block is that two of the LS1 head stud threads were cracked (and welded and cracked again). I'm going to 1/2" studs next. 15 psi was the boost in use.
I'm certain of the 1.105 CH since I measured it from those pistons and I got the same info from manufacturer later.
EDIT: Compression height calculator shows aprximately the same 1.105 CH when I put this stroke, connecting rod and deck height as values.
A High mileage JUNKYARD pulled LQ4 might will be cheaper, easier and very likely LAST LONGER under boost than a bunch of aftermarket parts and a local machine-shop effort.
In this case the old engine was with all this expensive stuff, so it's easy to build a new block around them. If I didn't have those parts, I'd gone with stock stroke and have plenty of piston options.
