LQ4 Piston Weight
Old Oct 20, 2025 | 12:07 PM
malibudave's Avatar
Default LQ4 Piston Weight
480 grams - LQ4 Dished Press Pin Piston (piston only)
164 grams - LQ4 Press On Wrist Pin (same as a Gen III 5.3/4.8)
36 grams - LQ4 Piston Rings - Ring Land Sizes: 1.5mm-1.5mm-3.0mm
612 grams - LQ4 Gen III Connecting Rod (same as Gen III 5.3)
40 grams - LQ4 Connecting Rod Bearings (same as a Gen III 5.3/4.8)
Here is a video of the Gen III and Gen IV Piston and Connecting Rod weights
Here is a video of the Gen III and Gen IV 5.3 and 4.8 Connecting Rod weights
2008 LY6 6.0 Truck Piston and Rod Weights
https://ls1tech.com/forums/generatio...surements.html
Old Oct 20, 2025 | 02:45 PM
Full Power's Avatar
Kinda surprised the 4.8 rods weigh same as 5.3
Old Oct 20, 2025 | 04:07 PM
Full Power's Avatar
[QUOTE=malibudave;20628046......................... ............... correct info. 4.8 rod weighs more than 5.3/6.0 rod.[/QUOTE]
. How much more is LQ9 piston over LQ4 ?
Can one just slap in some flat-top LQ9 slugs and run 'em without "Re-Balance"?
. " In the old days, we'd dingle- ball hone a stock truck 350, slam some 11 to 0ne forged pistons on stock rods, torque it all back together and bounce off 6500 rev limiter for hours on circle track---- never even KNEW ANYBODy at the track got anything balanced.
...did we all get LUCKY for 40 years ?
Seriously- How critical is "BALANCE ?"
Old Oct 20, 2025 | 08:16 PM
Balance is critical for overcoming harmonics. It’s NOT gonna blow up if you don’t balance…but it will turn more rpm if you do balance, all by itself. Harmonics hold back rpm. Harmonics are always in place, but you have the ability to move the harmful harmonics to where it’s not an issue by balancing the assembly. Balancing is a way of telling the assembly where you want the power to produce itself. Example…we PURPOSELY overbalanced our Cup engines 15 grams to increase acceleration out of the corners on our short track program. You CANNOT show or prove that on a dyno, but consistent lap times don’t lie. We could pick up an honest tenth a lap by speed balancing our test tires at testing outings. Balancing matters a lot. It puts you in control of harmonics…not putting harmonics in control of you.
Old Oct 24, 2025 | 03:36 PM
malibudave's Avatar
Flat top Enginetech “replacement” piston standard bore 6.0 LS - Part Number P5041
498 grams piston
144 grams floating wrist pin
2 grams floating wrist pin clips
644 grams total weight
The Enginetech replacement piston, Enginetech floating wrist pin, with the Gen IV rod will be heavier at 34 grams over the weight of the Gen III stock piston, Gen III stock rod, and Gen III stock wrist pin.
Old Oct 29, 2025 | 06:35 PM
malibudave's Avatar
Flat top Silvolite “replacement” piston standard bore 6.0 LS. Part number 3527HCA-STD
500 grams piston
152 grams floating wrist pin
654 grams total weight
Ring Land Sizes: 1.2mm-1.5mm-2.5mm
Old Oct 30, 2025 | 07:29 PM
Full Power's Avatar
Originally Posted by malibudave
Flat top Silvolite “replacement” piston....................................
500 oz piston.
Damn, that's heavy duty parts. 500 ounces is 31 POUNDS.
Gonna take a shitLoad of Mallory Metal to balance that one.
Old Oct 30, 2025 | 08:38 PM
malibudave's Avatar
Sealed Power H1506CPA replacement 6.0 LS piston
488 grams piston
148 grams flaring wrist pin
638 grams Total
Old Oct 30, 2025 | 08:59 PM
Oh why not…31lbs times 8 pissdons is 248lbs. Prolly rev slow, but once you get it moving…..
Old Nov 7, 2025 | 12:10 PM
malibudave's Avatar
SILVOLITE Hypereutectic Flat Top Part Number 3517HC
490 grams piston
152 grams flaring wrist pin
644 grams Total
