LS6 Z06 Cam Questions
Ported 706 heads that were milled and the OG 212/218 comp cam. 54-412-11
But I am also Factory Flex Fuel. So if they question anything, I blame it on the Ethanol... Even If they were to Sniff it, E85 burns cleans...
All Stock appearing...
Only had 1 tech say it doesn't seem stock. But he couldn't figure it out.
Duration might be too big in CA? Maybe not.
https://briantooleyracing.com/btr-ho...4ENgxlLiTY4EHa
Hey guys, here's the deal about big cams and Cali smog checks- If the cam lopes much at all, it will throw an intermittent miss code. Not good.
One thing people forget- lope might sound cool, but IT'S A MISS, PEOPLE!! And misses puke all kinds of nasties the smog guys kinda frown on only slightly more than a WHOLE BUNCH!
So quit wondering why ratty cams don't (and shouldn't) usually pass smog. Otherwise it kinda defeats the whole purpose......
Back in the day I believe the 224/224 114LSA cam would pass smog. Rick HollenBack who used to own Synergy Motorsports in CA could provide some more insight. He is now in AZ.
You could also try GP Tuning in SF Bay Area for one of their CA cams.
https://www.instagram.com/ricktuned/?hl=en
So overlap breaks up the “perfectly smooth” procedure that an internal combustion engine would have with valve events backed up to where cylinder pressure is MINIMIZED to make the engine actually run. Overlap (positive overlap) is the valve event procedure pushed into an area where cylinder pressure is both maximized….depending on measured amount of overlap of course….and actual efficiency is discarded for the purpose of making power. The breakup of the “low cylinder pressure smoothness” is traded…by order of valve events…for the search for max power, causes the engine to hiccup, or buck…which is what we refer to as lope. Add RPM…or LOAD…to the engine and the lope clears up because of the VE is increased by fueling measures. That’s what lope…or cam surge…is in a nutshell.
Just wanted to follow up that I ended up reaching out to Tony Mamo to get his help with the cam for my deal. It will have a bit more lift than the Ghost cam and slightly less duration as well. -7 overlap. I went with Johnson drop in lifters as well.
very cool. what are the specs?
Yeah, whenever anyone talks about running the GM Hot Cam, I feel like they're cheating themselves. IMHO, there are 2 kinds of Hot Cam owners. Owners who've removed them in favor of a modern grind, and those who will......
