LS6 Z06 Cam Questions
New engine build and I'm trying to decide on the cam. Its a California car so I'm trying to keep the overlap low and the idle chop to a minimum. What is the opinion of the stock 02-04 LS6 cam verses the older design Lingenfelter GT2-3 cam? I know they are very similar but I can see the lobes are more aggressive on the GT2-3 cam when comparing the advertised and @ .050 duration numbers.In addition, it does have a bit more lift. Is there a better/modern choice other than the GT2-3 cam?
Intake Duration at 050 inch Lift:
207
Exhaust Duration at 050 inch Lift:
220
207 int./220 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:
0.571 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:
0.578 in.
0.571 int./0.578 exh.
Lobe Separation (degrees):
118.5
Build:
LS6 block
Mahle power pack pistons. .005 over
Compstar rods
Stock crank
CNC ported 243 heads
Manifolds to pass smog, then install headers
Possible blower in the future
207
220
207 int./220 exh.
0.571 in.
0.578 in.
118.5
Build:
LS6 block
Compstar rods
Stock crank
I would have a serious look at the Summit Racing Ghost cam. It makes good power with a subtle idle.
https://www.summitracing.com/parts/s...lScbD1ncXvaW5d
While the @0.050 duration numbers are higher, the advertised duration is very similar to the stock '02+ LS6 cam, with about 10° more exhaust duration. This means the ramp rates are a little more aggressive and where the extra power comes from. The Ghost cam is also advanced 3° vs the LS6 cam which is retarded 2.5°. The 5.5° of total advance will help the cam come on sooner in the low end. It shouldnt sacrifice much if anything down low, and have a stronger top end.
Will the -2* overlap be enough to pass the sniffer tests in CA?
1) Visual for missing/unauthorized parts
2) Plug in the OBDll scanner for any codes.
Your car might easily pass as long as you're using CARB legal VISUAL parts and there are no codes showing. That's literally all that goes on now.
I wasn't aware of that, good to know.
207
220
207 int./220 exh.
0.571 in.
0.578 in.
118.5
Build:
LS6 block
Compstar rods
Stock crank
207
220
207 int./220 exh.
0.571 in.
0.578 in.
118.5
Build:
LS6 block
Compstar rods
Stock crank
Not all vehicles show that it has been tuned and they don't have all the records on early vehicles...
Newer cars do have counters for that to show how many times an ECU has been flashed.
I can tell you my personal cam and heads tuned vehicle passes smog.
I’m boring, so I’d just run the LS6 cam. I’d rather give up 5-10 hp and have peace of mind that I’m running a cam that’s easy on the valve springs and I never need to worry about them. Don’t have worry about drivability, emission tests, etc.
I guess I’m a hot fodder at heart and want that extra power if I can get away with it.
what cam and heads do you have? Will help us tell how small we should stay / how big we can go.
But I am also Factory Flex Fuel. So if they question anything, I blame it on the Ethanol... Even If they were to Sniff it, E85 burns cleans...
All Stock appearing...
Only had 1 tech say it doesn't seem stock. But he couldn't figure it out.
