Compressed Air for Valve Spring RR, what psi?
Checked the previous posts, still haven’t come to a conclusion on what PSI will be needed for the spring swap to hold the valves up. Heard 30-40 and 90-100, but wouldn’t want too much to push the piston down. Any experiences?
I do know the rope trick also, not ruled out yet.
I've never done anything other than making sure the piston under the valve spring is at TDC, that way when I crank the spring compressor down on it the valve keepers pop loose from the valve just touching the piston top it won't hurt anything if you are gentle there was a sequence how to do it on "LS1 how to" back in the day
If the piston is at TDC, then you wouldn't have to worry about the air pushing the piston down as there's no lever action to the crank at TDC.
Having the piston at TDC is a safety because you know $#it happens.
80-100psi should be more than good. IF you're worried about the piston moving down the cylinder, you can also put a breaker bar with a socket on the crank bolt as a visual.
Thanks all, appreciate the responses. Actually doing the cam too so had the timing marks pretty accessible, and used the TDC method. #7 & #8 was the worst, but got through it all.
Just take your time and definitely ’cover’ the area/valves you are working on to capture those flying keepers.
