Engine Removal Time
Old Aug 2, 2004 | 10:07 AM
Cerebrex's Avatar
Default Engine Removal Time
Taking hte engine out the bottom.... about how long am I looking at, it being my first time? How long did it take you guys? Starting here in just a sec!!!
Old Aug 2, 2004 | 10:16 AM
antz01ta's Avatar
10 Second Club + 14 Second Truck Club
4 hrs no problem
Old Aug 2, 2004 | 12:50 PM
Cerebrex's Avatar
is it better to go with a write up or just look to see what needs to be done, and do it?
Old Aug 2, 2004 | 01:11 PM
antz01ta's Avatar
just do it, its very simple. i cant stand all of these guys on the board asking how to take the engine out, look at it and do it, whats so hard about it. if you need to be told to disconnect the steering shaft to drop the k-member then you dont belong under the hood.
i'm not picking on you but every other post on this board is about how to drop the motor.
Old Aug 2, 2004 | 01:40 PM
Cerebrex's Avatar
I'm not asking how to do it. I'm asking how much time is involved. Besides, are you born to belong under a hood? No; it's something that you learn. Trust me, I have searched, and there aren't too terribly many threads on engine removal. Thanks for taking your frusteration out on me, though.
Old Aug 2, 2004 | 05:21 PM
antz01ta's Avatar
sorry man and i wasnt implying that you needed instruction on how to do it or you couldnt do it, it just seems that most people dont want to try anything without someone holding there hand to do it.
it's really a piece of cake the first time i did it it took me about 4 hours, by the third one i can now do it in about 3. good luck
a little tip if you take the tranny out first it makes getting to the wires on the back of the cylinder and manifold alot easier to get to.
Old Aug 3, 2004 | 12:07 AM
Cerebrex's Avatar
Thanks for the tip... but I always have trouble with the tranny.... so we'll see how it goes. I've spent about 2 hours and I've got most of the **** undone from the top.
Old Aug 3, 2004 | 12:16 PM
Cerebrex's Avatar
well... discovered my oil pan, filter, and half my tranny was soaked with oil... may be part of the reason I'm having to swap motors... lol.
Old Aug 3, 2004 | 12:48 PM
DEEZ98Z's Avatar
Make sure that you watch the brake lines when droping the the k-member. Oh and it took me 2.5 hrs by myself with a lift and air tools
Old Aug 3, 2004 | 02:23 PM
Inspector12's Avatar
TT-TECH Veteran
Iv'e done it in an hour or less with the help of a knowledgeably friend that I didn't have to show him what to do and it was very fast! I do it by myself no lift I just use an engine hoist in about 1.5-2.0 hours. And as far as the wiring goes I take the engine and trany with the engine harness with it I don't try to get anything that takes major time I just drop the whole thing and then take it apart on the ground with air tools etc... Here are a few pics.
Old Aug 3, 2004 | 03:26 PM
JL ws-6's Avatar
Race your car!
How do you attach the strap to the car? That looks like the easiest way I have seen for a do it at home job so far.
Old Aug 3, 2004 | 04:17 PM
TT-TECH Veteran
This particular time I attached 4 5500lb straps from the lift to the front crossbar that goes across the frame rails, but in a few day when I have to take it out agian to install some forged pistons etc... I plan on attaching one strap around the core support. It allows me the maximum amount of lift etc...
Old Aug 3, 2004 | 06:35 PM
IRVINEWS6's Avatar
That's cool! However, I don't think my garage is tall enough to lift the car that high.
I installed my heads and cam, and I would rather do it your way then go through what I did to change my H/C.
Old Aug 3, 2004 | 07:59 PM
TT-TECH Veteran
10 ft celings but you could so it in an 8ft garage you would just have to remove the hood. Just a few to think about.
