Difference between Fbody and Corvette LS1
Old Aug 4, 2004 | 10:17 PM
Cerebrex's Avatar
Default Difference between Fbody and Corvette LS1
I'm about to throw a corvette LS1 into my trans am. What the hell are the differences? I have already found out the crank pullys are different, and I have fixed that. Anything else I will run into? What are all the differences as far as installation is concerned?
Old Aug 5, 2004 | 12:00 AM
Cerebrex's Avatar
doesnt anyone ******* know
Old Aug 5, 2004 | 12:36 AM
CaptUSA's Avatar
Damn G, give it a little more than two hours before you start to flip . TTT for you though.
Old Aug 5, 2004 | 12:44 AM
Hayze's Avatar
must be that time of the month
Old Aug 5, 2004 | 12:49 AM
jrp's Avatar
jrp
SN95 Director
drive by wire TB, alternator bracket in different spot, ect. the main short/long blocks are the same though. cam specs are different but its neglible.
Old Aug 5, 2004 | 11:41 AM
OWENMUSTANG's Avatar
agree and add the oil pan is different.
Old Aug 5, 2004 | 11:44 AM
Deckhand's Avatar
Old Aug 7, 2004 | 01:41 PM
Cerebrex's Avatar
More than two hours? That time of the month? What the **** would you do if you were installing it and finding differences that hadn't been mentioned to you before? I am in Dallas on leave to fix this ****, and if it doesn't get fixed, it sits here longer. It's very frusterating and I especially don't need that last kid just looking for an excuse to use that picture, which was old news 5 years ago. Let's get something original if we are going to be an *******, OK?
Old Aug 7, 2004 | 01:48 PM
Colonel's Avatar
You're not going to get alot of help around here with that kind of attitude and no patience.
JRP summed it up well though.
Old Aug 7, 2004 | 01:50 PM
Cerebrex's Avatar
Did you read my post?
Time restrictions.... if I wait patiently.... I get no engine when my leave ends.
Now, by bumping it up there I received the response I needed. Close this thread because we both know I will argue with God if he posts in this thread because of how frusterated I am right now w/ this engine.
Old Aug 8, 2004 | 09:45 AM
monyhunter's Avatar
DUDE, you have some major issues, and they are NOT with your car. How are YOUR time restrictions our problem?????? Why don't you do a little more research before you start your project?
Go **** yourself, and your engine install too!!
Old Aug 8, 2004 | 11:59 AM
Mooobunnny's Avatar
Damn you guys are soooo sweet!
Old Aug 8, 2004 | 12:09 PM
Hayze's Avatar
Old Aug 8, 2004 | 12:44 PM
cfi_luz's Avatar
Most of the major differences are; none of the front accessories are going to line up, you will need an A/C compressor, alt bracket, ps bracket, etc. and balancer pulley from an fbody. The motor mounts are different, as is the oil pan (corvette has windage trays, fbody is more like a traditional pan), throttle body on the vette is fly-by-wire, fbody is cable operated. Also, the exhaust manifolds are going to be different. Other than that the other changes are not worth worrying about; slightly different cam specs and +/- injector size depending on year.
