Royal Purple?
Old Mar 25, 2003 | 09:58 PM
Jackyl_30's Avatar
Default Royal Purple?
Coming up on my 3rd oil change (about 2000 miles on new engine). I thought I read somewhere long ago that this is decent oil. Is that true? At almost $6 a quart I would expect some quality. Opinions
Old Mar 25, 2003 | 10:12 PM
richieg's Avatar
Default Re: Royal Purple?
Call me crazy, but In my ta, I actually notice a difference with royal over mobil one synthetic. I had always used royal in my ta, a couple of oil changes ago, I was wondering the same thing you are, so I used mobil one instead. I did notice a performance decrease vs. the royal. Just my experience.
Old Mar 26, 2003 | 12:29 AM
VTtransam's Avatar
Its a GREAT oil, I've always used it in my TA, along with all of my family's vehicals, tractors, and equipment. I highly recomend it!
Old Mar 26, 2003 | 12:33 AM
98sspullin'em's Avatar
i used rgular motor oil then switched to purple and runs a lot smoother and a little more power. i read that you gain 10.2 HP useing purple vs. regular!!
Old Mar 26, 2003 | 05:03 AM
Patman's Avatar
The newest formula of Royal Purple is better for the LS1 than Mobil 1 for two main reasons. One, it's thicker in viscosity (Mobil 1s 5w30 and 10w30 are almost 20wt oils) and two, it contains more moly in it.
I'm running Royal Purple 5w30 in my wife's car right now, and will be doing oil analysis on it to compare it to Mobil 1.
Old Mar 26, 2003 | 10:47 AM
MattB4C's Avatar
where can you get royal purple and how much does it cost? anymore than other synthetics?
Old Mar 26, 2003 | 05:04 PM
Jackyl_30's Avatar
I get it at Peterson AFB gas station suprisingly.
Old Mar 26, 2003 | 05:09 PM
GoFastTurnLeft's Avatar
Thunder Racing sells it.
Old Mar 26, 2003 | 07:47 PM
minivette's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Patman:
<strong> The newest formula of Royal Purple is better for the LS1 than Mobil 1 for two main reasons. One, it's thicker in viscosity (Mobil 1s 5w30 and 10w30 are almost 20wt oils) and two, it contains more moly in it.
I'm running Royal Purple 5w30 in my wife's car right now, and will be doing oil analysis on it to compare it to Mobil 1. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Patman, are you referring to the race version? or the regular version you can find at NAPA?
EDIT: I am referring to Royal Purple
<small>[ March 26, 2003, 07:57 PM: Message edited by: minivette ]</small>
Old Mar 27, 2003 | 05:04 AM
Patman's Avatar
I'm referring to the regular street version of RP.
Old Mar 27, 2003 | 09:49 PM
alexWS6's Avatar
Patman- I'm running 10w30 RP, would it be worth anything to switch over to their race series next time around?? It will probably be around summer time, but still seeing track use here and there.
Old Mar 27, 2003 | 11:38 PM
BADZ's Avatar
Moderator
Besides Redline product's, this oil is from what I here #1... <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Mar 28, 2003 | 12:01 AM
Screamin_Z's Avatar
I seen a test of Royal Purple on the dyno, on a well treated (stock)LT1 auto. The company used RP oil, tranny, rear end and water weter fluid. They gained 7.? hp 10.? tq at the rear and spent about $100. u deside if it's worth it
Old Mar 28, 2003 | 04:33 AM
Patman's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by alexWS6:
<strong> Patman- I'm running 10w30 RP, would it be worth anything to switch over to their race series next time around?? It will probably be around summer time, but still seeing track use here and there. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No need to use their race oils, their 10w30 is already very good, plus it's cheaper too I believe.
