think i broke something
Old Aug 8, 2004 | 05:09 PM
pdd's Avatar
pdd
Default think i broke something
i down shifted on the highway and hit the wrong gear overreving the **** out of the car. now i have no power and its running shittiy and bucking. any ideas. and im at work 40miles away from my house. i dont know if a should drive the car or not. i need help asap
Old Aug 8, 2004 | 05:11 PM
foff667's Avatar
LS1TECH Sponsor
bent pushrod possibly, and i wouldnt drive it till u fix it.
Old Aug 8, 2004 | 05:12 PM
HumpinSS's Avatar
bent pusrod. I would take an hour out to pull the VC and find out
Old Aug 8, 2004 | 05:15 PM
pdd's Avatar
pdd
pushrods are hardend. do they still bend??
Old Aug 8, 2004 | 05:17 PM
HumpinSS's Avatar
That would be the cheapest to check right now. Then on to the valves
Old Aug 8, 2004 | 05:18 PM
pdd's Avatar
pdd
would i srcew up the drivin it with bent valves or pushrods. im 40miles or so from my house. its gonna cost some bucks to tow it
Old Aug 8, 2004 | 05:20 PM
Scalpel's Avatar
You've most likely bent the valves and eyelashed the pistons.
I wouldn't drive it anymore, poor air/fueling control with bent valves, could wash down the cylinder walls and toast your rings.
Old Aug 8, 2004 | 06:45 PM
JoeDirt's Avatar
, with hardened pushrods youve probably got a little bit of a mess in there . .
Old Aug 8, 2004 | 06:47 PM
foff667's Avatar
LS1TECH Sponsor
ouch man, and you just got that thing back together like this week didnt you?
Old Aug 8, 2004 | 06:51 PM
pdd's Avatar
pdd
a few weeks back
Old Aug 8, 2004 | 07:55 PM
Fireball's Avatar
since you removed the weak link (stock pushrods) you probably have some seriously twisted up valves...
SHould check straightness of all valves (pull the heads), check guides and seats, etc
Pistons may have been banged up too...
Hopefully it isn't that bad
Old Aug 9, 2004 | 11:14 AM
Racehead's Avatar
You might think a tow is expensive, but if you drop a valve on the way home you'll be wishing you'd gotten off that cheap. It really looks like a valvetrain problem and they have a nasty habit of leading to a demolished engine if run that way. You've got a chance here to get off cheap by towing it IMO. I'd take it .
Old Aug 9, 2004 | 12:47 PM
Ryan02SS's Avatar
Tow it! Plain and simple. As was mentioned before with hardened pushrods you more than likely bent some valves. Hopefully thats all. Keep us informed on the situation.
Old Aug 9, 2004 | 12:56 PM
Boostaholic's Avatar
Update? Did you check to see if the pushrods were bent?
Old Aug 9, 2004 | 02:08 PM
94form2000z's Avatar
This is the reason if I had a m6 I'd use stock PR's. Sorry for you luck man.
On a side note. If you know someone with a truck. Go rent a sigle axle tow dolly from U-Haul. I just did this with my Sebring. Cost me $39/ day. Also if you have repairs done it is likely your insurance will cover it as towing.
Old Aug 9, 2004 | 02:43 PM
HumpinSS's Avatar
With an aggresive cam wont the cam bend the stock PR
Old Aug 9, 2004 | 03:19 PM
pdd's Avatar
pdd
i towed the car home. AAA is great. didnt cost me a dime.
Old Aug 9, 2004 | 03:31 PM
Pull thoes valvecovers and let us know what you find!
