Who has bored a 98' LS1 block?
Old Aug 13, 2004 | 04:22 AM
Hemi Killer's Avatar
14 Second Truck Club
Default Who has bored a 98' LS1 block?
How much did you bore it and where did you get the pistons?
Thanks
Old Aug 13, 2004 | 04:03 PM
redline2k's Avatar
I have always been told you could not bore the 98 5.7 block, something about the sleeve thickness tapers too much at the bottom. I am not sure about a 5.3 block
Old Aug 13, 2004 | 08:26 PM
ROCNDAV's Avatar
Thanks
You can safely hone 97~98 blocks .004"
99+ block can safely be bored .010"
I know Sam98WS6 has a stroked 383 and a 98 block. After following his posts and PM'ing him and a few others, I felt safe enough to go with 3.903 (.005" hone) Pistons. I just received my Lunati 395 rotating assembly. I hope my 97 block holds up
David
Old Aug 13, 2004 | 08:32 PM
ktmrider's Avatar
The key terms are "hone". The 97 C5 and 98 Camaro/Firebird blocks do not have enough meat to do more than 0.004" of hone. I have read this in numerous articles and have not heard of anyone going beyond this. Now you CAN re-sleeve the 97-98 blocks with no issues like the newer blocks if you are going big cubes.
Old Aug 14, 2004 | 12:26 AM
What would the cubic inch of a stock LS1 block be if it was bored .003" to a 3.901? What about .005" to a 3.903? And what if it had a Eagle 4.000" stroke crank in it? Thanks!
Old Aug 14, 2004 | 05:58 AM
SCAZ's Avatar
The formula is (3.1415/4) X (bore squared) X Stroke = cid per cylinder
Take that and multiply by 8.
You will see that .003-.005 first of all just a little more than a hone job and yields very little.
Old Aug 14, 2004 | 12:19 PM
ROCNDAV's Avatar
Here are some common bore & strokes that I have posted before.
https://ls1tech.com/forums/showpost....71&postcount=7
D
Old Aug 14, 2004 | 12:30 PM
onyxxtreme's Avatar
i have a 98 block taken out .007"
from 3.898 to 3.905 with diamond pistons
I talked to several experts about that, and all of em said that was BS that you couldnt take the older blocks out this far
Old Aug 14, 2004 | 12:50 PM
ROCNDAV's Avatar
That's good to hear. How many miles do you have on that engine?
My local machine shop told me the same thing as long as I wasn't planning on using a power adder, it should be OK to go to 3.903~3.905
D
Old Aug 14, 2004 | 10:15 PM
ktmrider's Avatar
That IS good to hear. Will open up more options for those with the older blocks. Thanks for the heads up!
Old Aug 14, 2004 | 10:17 PM
ktmrider's Avatar
Oh, and the displacement will be 382 CI with a 4" stroke at 3.901" bore. Go to 3.905" and you hit 383 CI. Like stated, very little change with a minor hone.
Old Aug 16, 2004 | 06:51 AM
SAM98WS6's Avatar
As posted I went to 3.905" without any issues. My car is an early 98.
383 Callies Forged Stroker.
Old Aug 16, 2004 | 07:06 AM
mitchntx's Avatar
I used a '97 block and it's taken to 3.905.
Old Aug 16, 2004 | 08:48 AM
CHRISPY's Avatar
Yep mine is out to 3.907
Old Aug 16, 2004 | 03:30 PM
ROCNDAV's Avatar
Sam, Mitch & Chris, what mileage do you have on those blocks?
David
Old Aug 16, 2004 | 04:33 PM
427 LS1's Avatar
I want to do a forged shortblock and add 12-14psi of turbo boost, I have a couple of 98 blocks, do you guys think it will last at 3.903-05 bore??
Old Aug 16, 2004 | 05:10 PM
CHRISPY's Avatar
Mine was at 3.906 for 3 years and 300+ passes.
Went out to 3.907 without any problems at all. About 800 miles on the new setup and ~20 passes so far. (Same block but I went to the stroker. 4 inch eagle crank, 6.125 rods and diamond custom pistons)
Old Aug 16, 2004 | 06:09 PM
fozziejared's Avatar
i just bought the 383 kit eagle with je pistons h beam rods. told that the pistons were set for 5 thousandths bore (.005? same thing right?) its a 99 ls1 block. good setup? 2400$. 4" rods i know just enough to be dangerous. also where to buy arp head bolts for cheap? thanks.
Old Aug 17, 2004 | 07:02 AM
SAM98WS6's Avatar
My motor had 59k miles on it..pounded hard. I have 4k on it now with no issues at all.
Old Aug 17, 2004 | 07:06 AM
SAM98WS6's Avatar
a 383 is a 3.905 bore so I would assume thats what your Eagle pistons are for. Get the part number and call the supplier or eagle to be sure.
427...if you are running boost why not get an iron 6.0L block machined from APE...they are cheap. You may be asking for trouble with a 98 block.
