I am looking for a rotating assebley
SN95 Director
get more decisive, if your not sure what you want how can we help you.
with that said seriously look into SLP' new rotating assemblies (use the search to find the info), or consider a nice 408 from HPE or APE, both have very great prices. with price being a factor the eagle route will most likely be your best bet, but it depends on your specific application. h/c is a whole nother story as everything again will depend on your specific application. do you see where im going with this
Yep same here but you need to know what you want out of the deal for the pistons. If you want a more custom piston it takes a little longer to get. Like JRP said we can do an Eagle 383 kit balanced for fairly inexpensive depending on pistons. The others can be much more pricey but the Eagle stuff has worked fine for us so far and it saves you a lot of money. We can balance them for an additional 100.00-150.00 depending on what we need to do to get there. We've only had to add one piece of heavy metal to one of the first Eagle kits so they are working our pretty well so far.
Originally Posted by Naked AV
What does this mean?
thanks guys for a little bit of help I am going to decide on a package and see where I need to go with that. I am new to the whole "bottom end thing" I may look into s/c charging the engine again later down the line......Will a 408 hurt that or should I just base my compression around that
408 won't hurt that, but compression will have to be lower ~ 9.0:1. Eagle components are great for the price. Figure out the budget you have to work with, your goals(whether it be road racing, peak RWHP, reliable powerful DD, whatever) and we can help you out a whole lot more. Knowing that you want to S/C down the road will help in building the motor now.
