How to mod an ASP pulley for a double roller timing chain?
Old Aug 17, 2004 | 10:43 AM
ArKay99's Avatar
Default How to mod an ASP pulley for a double roller timing chain?
I have a 99 corvette. I'm doing a head/cam swap in a week or so and bought an ASP ud pulley and a double roller timing chain. I've heard the us y-body guys have to trim the pulley to mate with the seal/oil pump. Does anyone know exactly what I have to do? I thought all I had to do was mill .125" off the back of the pulley. Then I heard I need to turn the collar in .125". Can someone steer me in the right direction?
Old Aug 17, 2004 | 11:03 AM
PREDATOR-Z's Avatar
That was on the old pulley not the NEW redesigned one.
Old Aug 17, 2004 | 11:09 AM
felton316's Avatar
You must increase the value of A (in the picture) by 3mm. If you have one of the newer ASP pullies, you may not need to machine at all.
Attached Thumbnails How to mod an ASP pulley for a double roller timing chain?-aspls1tech.jpg
Old Aug 17, 2004 | 11:11 AM
PREDATOR-Z's Avatar
That's what I said
Old Aug 17, 2004 | 12:42 PM
ls1290's Avatar
Dumb Ass Vette Moderator
How does the machining affect the balance of the pullie since it is internally balanced?
Old Aug 17, 2004 | 01:21 PM
ArKay99's Avatar
Thanks! That is what I needed. I assume the new pullies look like the picture. Mine does not. The narrower part of the collar is about 1/2 the width as the one in the picture. Gotta go down to the local machine shop.
Old Aug 17, 2004 | 01:27 PM
kickassT/A's Avatar
i dunno where you're located, but asp is in houston, right down the street from MTI. they do it for like $20 if i remember right.
Old Aug 17, 2004 | 01:58 PM
ArKay99's Avatar
Thanks man. I live in New Joisey. Too far, but there is a local shop I can use.
Old Aug 17, 2004 | 02:07 PM
slick98ta's Avatar
Here's a pic I found awhile back that someone took of the old style and one thats machined.
Attached Thumbnails How to mod an ASP pulley for a double roller timing chain?-asp_machined.jpg
