Valve leakage when CCing heads
if not, do it again .....if so. than you missed a spot!
-spread grease around seat and rim of valve
-install in head and spin a few times..
-wipe away any excess in chambers
this should work perfect.
now when your all done with assembly be sure to VACUM TEST your heads to asure proper seal!
if a port is leaking, just hand lap that valve, and try again! and try again untill ALL
ports are vacum tight!
THIS IS VERY IMPoRTANT!!!!!!!!!!!!!!!!!!! be patient.
and yes you can loose power! fix them before you install them!
give some more info on your method of cc'ing and vacum testing first!
you need to seal the valve with grease to properly cc the chambers.....
if they are allready assembled and they are still leaking! than you need to hand lap what ever valves are leaking untill that are all vacum tight!!!!!!
so are they assembled allready?
best to do it now.
