Newb to cams....needs suggestions
Old Aug 22, 2004 | 01:31 PM
ragingWS6's Avatar
Default Newb to cams....needs suggestions
I have an 01 WS6 with full bolt-ons (see sig). I went my best with a Midwest 2800 stall and the same mods. I went to the 3400 and lost 3 tenths. My goal is to hit 11s. I am not concerned with anything else. I would like to do this with cam only. I am also toying with TEA's Stage 1.5 heads a buddy wants to sell me for $1500. I am staying away from that since I know that it would blow out the 10-bolt (which the cam might do as well....and I am prepared for that) and the tranny. But it is easier to replace these two things without spending $1500 on heads. So, I would like to know what you think I need cam-wise in order to reach my goal (on stock heads). Also, if you have a recommendation for a cam to get if I were to go with the TEA heads, it would be appreciated as well. The stealthier the cam, the better! Thanks a bunch!
Old Aug 22, 2004 | 01:39 PM
cyphur's Avatar
well if you want a well mannered cam that will perform well on both stock and ported heads, i think you're look at a 224 type cam. they're proven, and since you're an A4 you're prolly going to want to go with a 114LSA, which will help keep the lope down a bit(keep the cam stealthier). you will still know you have a cam in there, no doubt. i think paired with a 3400 stall this cam will get you where u want to be. should pick up 25-30rwhp. OR, if u want to go slightly larger, you could look at a more aggressive cam, in the 228 range. that would definitely put you into the 11's w/o doubt, with room to spare.
i suggest you read jrp's cam guide. has a ton of great info in it. should get you well on your way to figuring out what cam u want.
Old Aug 22, 2004 | 04:01 PM
PREDATOR-Z's Avatar
380 rwhp will keep you planted in 11's,
224/224 .581/.581 114 XE-R Comp
224/224 .563/.563 114 TR
225/225 .589/.589 112 TSP
MTI X1 (on the bigger side)
FM11
G5X2
231/231 TSP
And the list goes on..........
Old Aug 22, 2004 | 05:53 PM
MUSTANGEATER's Avatar
With camshafts you can ask 10 people you'll get 10 different answers. Best bet is to decide on your Intake and Head combo then go looking for a camshaft. Once you know the rest of the combo it becomes a lot easier to manipulate things and you can start to do things like 12.5:1 compression on 93
Best o' luck
Floyd
Old Aug 22, 2004 | 06:08 PM
jrp's Avatar
jrp
SN95 Director
Best o' luck
Floyd
mine will be 12:1 on 91 , custom cams and DCR are a wonderful thing. that and tuning
Old Aug 22, 2004 | 08:52 PM
Who did your camshaft design?
Old Aug 23, 2004 | 08:05 AM
ragingWS6's Avatar
Best o' luck
Floyd
Floyd, I have pretty much decided that I am going to stick with stock heads. As for intake, I am going to stick with the LS6, if that is what you were referring to. As I explained before I am a newb...so explain how and why I would want to change my compression. I appreciate it as always.
Old Aug 23, 2004 | 10:32 AM
More compression = more torque by math more torque = more hp. Not to mention it's more driveable since you pick up power throughout the range. You can increase compression on a stock bottom end car by running smaller combustion chambers or milling the heads. You can easily make good power on stock heads with a good cam choice, but I think its a lil more tricky.
