Oil Consumption: It might be bad
Old Aug 31, 2004 | 12:54 AM
Christos's Avatar
Question Oil Consumption: It might be bad
Well, I picked up my 99 SS a few days ago. The owner said it burned about a 1/2 quart of oil in about 1,200 miles. I was told he had just filled it with mobil 1 10-30.
I've put about 130 miles on it since, and when I checked the stick, it was 1 qt low!
I haven't seen a speck of smoke come out of it. I guess I haven't really witnessed the oil consumption myself just yet either, but if it's this bad...
I've been reading up, and I guess people are saying the ls6 PCV mod, (I'd go catch can myself) and a Metco breather can help this somewhat. I did a quick search on the Metco breather, but I couldn't find a LS1 application.
Do these two modifications really seem to help that much? Does anyone have any input, or a link for the LS1 Metco breather?
Thanks!
Old Aug 31, 2004 | 01:17 AM
Christos's Avatar
n/m it looks like Fasttoys has the breather.
Does this, and the catch can really help out on oil consumption?
Old Aug 31, 2004 | 01:56 AM
calongo_SS's Avatar
a catch can won't actually stop you from losing oil, it will just stop it from getting going into your intake. a full quart in 130 miles sounds like a lot more than the average pcv problem though.... good luck
Old Aug 31, 2004 | 12:37 PM
Christos's Avatar
Yeah, I can't say for sure just yet. I'll be paying close attention to the oil level in the meantime.
Old Aug 31, 2004 | 12:43 PM
c2a0m0a0rSoS's Avatar
There was a GM tech bulletin (so I've been told) that says it's okay for the LS1 to burn about one qt. per oil change.
Also, I've read somewhere that the LS1 should run a 5w-30 becase the clearance tolerance dosen't allow for the heavier oils.
I know this dosen't help much now...
