JMX cam install suggestion
Here is the trick to help lining up "DOT TO DOT"
Once you remove the timing cover, prior to taking off the cam gear, remove the spark plugs so the engine is easier to turn over by hand then line the dots up so you make sure it is lined up 100% before you take the gear off. Plus you get to see what lined up really looks like. Very nice to have them lined up 100% then take the cam gear off, pull the cam, put the new one back and the crank gear is already straight up and you are positive of that.
Again just an idea that made the dot to dot issue not even a worry, hell I had no PtoV problems doing it that way with the TREX and it took my 2 minutes to get the dots lined up because the crank gear was already correct.
Mike
You're right though, if its not in the install guide it SHOULD be. A lot of people use that.
Thanks.
it was 1fastWS^ that said "I think it's common knowledge to do that before removing a cam. If you don't, then you have a chance of installing the cam 180* off since the dot on the crank gear will be on top twice (once for #1 TDC compression stroke, once for #1 TDC exhaust stroke)." I just said that was another reason why I did it so I wouldnt have to consider any other possible problems.
