What would cause a motor to knock?
Old 08-31-2004, 01:23 PM
chrdij's Avatar
Default What would cause a motor to knock?
I stripped down my old knocking 103k ls1 yesterday and could not find anything thing at all. All the rods where still there and all the rod bolts where still there. I did notice a good amount of Aluminum shavings in the oil pan. All the cylinders looked great, and no noticeable damage to the crank, Could bad rod bearings cause it to knock so loud you cant hear anything else around you? Any info would be great, Thanks chris
Old 08-31-2004, 01:27 PM
Boostaholic's Avatar
Rod bearing, check the cylinder heads and pistons for any excessivly clean spots where it was hitting.
Old 08-31-2004, 01:29 PM
WAHUSKER's Avatar
Is 1 (or more) of the pistons 'loose' on it's wrist pin?
Old 08-31-2004, 01:34 PM
Onyx Z's Avatar
Just because you can't noticeably see something, doesn't necessarily mean they're not bad. Maybe you weren't getting oil to one or more of the bearings for a short time. Cam bearings? Rod bearings?
Old 08-31-2004, 02:28 PM
chrdij's Avatar
Not sure, I will start taking the whole thing apart 2morrow and will soon see thanks
