Flycut pistons and Nitrous.. come on in.
I flycut my pistons a while back and I have been thinking about sticking my wet kit back on the car. I usually sprayed 50 or 75 on it and would NEVER go over 100rwhp if I put it back on the car. Is anyone spraying their stock flycut pistons? If so, how much and have you hurt anything?
Will I be safe with 100 octane, rich tune, and 100rwhp wet on my flycut stockers?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
I fly cut both the intake and exhaust. Spraying a TNT 150 shot, put a few bottles through so far. Pulled the passenger head last night (due to a few Comp R's collapsing) and it looked fine. Did a leak down test before I pulled the head, all cylinders looked good.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by Kurtomac
yea the sides usuallly break away before the center does
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
No need to run rich, just run right on. Unburned gases can be pre-ignited in the flycut pockets. as long as you are properly tuned and do not have any hot spots from carbon build up, you'll be fine.
IMO I would run a bottle of RedLine fuel system cleaner on 1 full tank, a few WOT runs and that should clean anything up.
