View Poll Results: Which Engine is Better
Linengfelter LS1
37.50%
Speed Inc. LS1
62.50%
Multiple Choice Poll. Voters: 8. You may not vote on this poll
Crate Engines
Old Sep 1, 2004 | 02:00 PM
silverbullet89's Avatar
Exclamation Crate Engines
Ok I want a faster engine in my car and then later turbocharge it...
But first I need to pick a good engine.
First I looked at the Linenfelter Crate LS1 that puts out around 450 Hp at the Crank. And is probably really well built with some of the best parts. http://lingenfelter.com/pac350ls1crate.asp
But there is also the Speed Inc. 383 Crate Engine another beefed up LS1 but I dont have as much info on this one but I know its a superb engine and can handle alot. Anybody who knows any **** about this stuff help me decide which engine is better and faster.
http://www.ls1speed.com/engine14.cfm
Old Sep 1, 2004 | 02:13 PM
Boostaholic's Avatar
There are more companys that make crate(long block) ls1 motors, check out HPE and some of the other sponsors
Old Sep 1, 2004 | 02:30 PM
Naked AV
Guest
Posts: n/a
Agreed - HPE, APE, FMS, etc. are all good places to check out. Course, you could always order a GMPP crate engine (i.e. LQ4/LQ9) and do-it-yourself (i.e. cam) to save some money.
Old Sep 1, 2004 | 02:57 PM
Lostpatrolman's Avatar
SLP has a forged 408 shortblock for cheap. Only problem is, it is an iron block.Weighs around 95 pounds more.
Old Sep 1, 2004 | 02:59 PM
And its a 402 (4.000 x 4.000)
Old Sep 1, 2004 | 03:17 PM
cyphur's Avatar
and its 105lbs heavier
Old Sep 1, 2004 | 03:21 PM
Chuck@'s Avatar
Actually it's only 70-75.
Chuck
Old Sep 1, 2004 | 03:23 PM
cyphur's Avatar
Reeeaaallly?? Are you referring to SLP's block, or the normal LQ9? I always thought the LQ9 block was 105lbs heavier then the LS1....
Old Sep 2, 2004 | 12:28 PM
mdhmi's Avatar
If your going to go FI my advise would be to build a low compression forged 346. Larger cubes = larger invoice .
Mark
