Heads and Cam
Old Sep 1, 2004 | 07:52 PM
white2001formula's Avatar
Default Heads and Cam
Going to install Patriot Performance Stage II 5.3 heads with 225/225 .589/.589 112LSA this weekend. Hoping everything goes well.
I have one question. My only concern is lining up the two dots on the camshaft/crankshaft sprocket. How difficult is it to do? I purchased the rollermaster single chain and sprocket set. I watched my friends 98 TA a few years back bend 3 valves, because he had it 5 degrees off. (One of the stock sprockets had 2 dots.)
Any input would be greatly appreciated.
Thanks
-Chris
Old Sep 1, 2004 | 08:22 PM
Lostpatrolman's Avatar
http://www.ls1howto.com/index.php?ar...e24199326494e3
Old Sep 1, 2004 | 10:49 PM
pdd's Avatar
pdd
Originally Posted by Lostpatrolman
Old Sep 2, 2004 | 08:48 AM
cyphur's Avatar
Originally Posted by pdd
Old Sep 2, 2004 | 10:53 AM
PREDATOR-Z's Avatar
Personally, I put a little white paint on the dots so I can see them properly. Then you got to look at them from top or bottom, not from the front so you can get a better view of the line up.
Also before teardown, line up the existing cam dot to dot, that will help also with crank position, then mark the crank stub to the block (white paint again).
Maybe those tips will help, it does for me.
Old Sep 5, 2004 | 11:44 PM
Everything is installed finally! Thought it was never going to end. My only concern is the new valve train noise. (Yes I did use the search button! ) Rather loud. It made us sit back and wonder for a while. Other than that, it sounds awesome. Hopefully the sound that I hear in the valve train is similar to everyone else's. Has anyone had a decrease in valvetrain noise as time went by?
Old Sep 6, 2004 | 03:02 AM
cyphur's Avatar
I get to enjoy the experience here soon myself...soon as the ride gets back from AMS....just waitin on my clutch to get in. Then after I break the Spec 3 in, in goes my 231/237.
Old Sep 6, 2004 | 06:26 AM
DD966's Avatar
I don't know whether its quieter or I'm just used to it.
Old Sep 6, 2004 | 06:38 AM
Naked AV
Guest
Posts: n/a
I've heard that many times the noise is from smaller base circle diameters on the new cam, with no adjustment of push rod length to match. For example, FMS recommended a cam to me and said that I would need 7.45" pushrods if I wanted no valvetrain noise with their cam....it was a pretty mild cam also. Good luck!
Old Sep 6, 2004 | 07:09 AM
PREDATOR-Z's Avatar
Well That is where adjustable rockers come to play. If only they could make some at a decent price and that fits all LSx heads without clearance issues.
Old Sep 6, 2004 | 05:52 PM
Thanks for all the input . I'm going to get it dynotuned in Lubbock, TX on Wednesday. I'll see what they think. BUt the noise doesn't really bother me when I go out of town for a nice "leisure drive"
