Need help, 427 Oil sump hitting pan
Location: Used to live in South Texas, Now in North Carolina
Everything is ready to roll but I cant get the oil pan on all the way b/c the oil sump tube is hitting the oil pan. Its hitting right were it makes its final bend to the pick up screen. I know I can noch the pan but Im wondering if anyone else has run into this problem.
The block came with main studs which I am guessing are ARP or something like it. Anyway they hold the windage tray a little lower then a stock motor and there for hold the braket for the oil sump tube down a little further. I think this and the spacing on the roll-master timeing chain are causeing it to hit.
Its a 427 c5r block with a stock z06 pan and stock oil sump.
Its going in a vette, not the car in my sig....I know a vette pan won't fit a f-body.
Thanks for the help
Thanks for the help
