How to limp home on a broken valve spring?
Its not that hard...
just need an 8mm socket...a 10mm socket....maybe a short extension.. a torque wrench good for 22ft-lbs.... a valve spring tool.... and a little patience.... just be sure to get th ecylinder to tdc before removing the old valve spring...
then you can limp it home safely at a low rpm...where at home you can then tear into the motor and look for a bent valve or a screwed up piston....or other issues...
Kyle
The last time I limped it home it resulted in a bent valve. I'd get it towed back to the house someway.
Tow bar rental :$50.00
Tow truck [depends on total mileage] $75- $300.
LS1 replacement engine: $2000 +.
If cash is the problem you have 2 options:1) rent a two-wheel dolly from U-Haul, cheap, safe, effective...just make sure you have a buddy that can tow it, and has the power hookups. or do it in the daytime, that should be ok as long as you can see the tow-vehicle's brake lights from around the car.
2) buy a cheap tow-strap, drop the sucker in neutral, and have a buddy (that you can trust) steer. only do this a short distance. very cheap, done it before. but you have to be VERY CAREFUL. choose the person who drives it well, and drive slowly. if they hit the brakes hard, the driver of the tow-vehicle will get a big surprise.
I wouldn't even replace the spring since the valve may already be bent. If it was a double spring and only one of them broke then you're probably in good shape and can change it out, but other than that, tow it.
So no one has done this to limp home from the track or something? I thought I had read about it before. I just don't have an extra spring handy. It's either this or a 170 mile tow with a smelly driver.
My friend Frank who replaced it said I was a verrry lucky guy.I broke the valvespring in BFE (Effingham, Illinois) in June of 2002 (or was it 2001?). At any rate, the dealer wanted $1000 just to pull the head and check the valves. I ordered a set of 918's and just had them replace all the springs.
I had autotap running the entire way back home to Orlando monitoring the misfires. Piston didn't need to be replaced or cleaned up, IIRC. I didn't feel comfortable with only changing one spring, then having another pop every couple of hundred miles
I would not have peace of mind without changing all the springs. I've ruined two motors due to broken valvesprings.
Also a magnet is handy to help get the locks
TIA!
Terry
Also having that much oil pressure on your lifter without load on it is a bad thing, I've heard of them coming apart before because of excess oil pressure without load (Little bearings everywhere!)
I say drive it!!
