ASA cam questions
Old Sep 10, 2004 | 03:12 PM
NataSS Inc's Avatar
Default ASA cam questions
I am thinking of replacing my X1 cam with an ASA cam. Specs on the X1 are:
230/227 .591/.571 112lsa
Specs on the ASA are
226/236 .525/.525 108lsa
My concern is P2V clearence. I currently have a problem with it and the X1 because my heads are milled .030. Would I be running into the same problem with the ASA cam?
ANY input would be greatly appreciated.
Old Sep 10, 2004 | 03:22 PM
RyanJ's Avatar
SSU Moderator
I thought the asa was a 110lsa? Arent the GMPP LS6 head milled? ASA cam works with those. Plus with .525 lift...I don't think its a question.
Old Sep 10, 2004 | 03:47 PM
NataSS Inc's Avatar
I am probably wrong on the lsa. It might be a 110
Old Sep 10, 2004 | 04:01 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
It's 110.
Call me nuts, but I'm thinking of replacing my cam with the ASA when the springs I have on now finish their life cycle (new springs and ASA = never changing springs again). Either that, or I'll just go bigger with the TSP MS3.
Either way, you should not have any problems with PV clearance.
Old Sep 10, 2004 | 04:35 PM
NataSS Inc's Avatar
My concern is that the ASA has more duration, which normally means that the valve would be opening sooner and closing later than the X1 cam. Which could lead to even more P2V problems. Bt thats why I am asking here. I called a couple of places asking if they had any experience with the ASA and came up empty handed.
Old Sep 10, 2004 | 04:51 PM
!LS1 11 Second Club
Try LG.
Old Sep 29, 2004 | 03:33 PM
cyclerage's Avatar
Default ASA cam
I just finished my h/c install. Its a GM ASA cam and heads(milled .055). Had no ptov problems and it idles awsome sounds very aggresive but the car doesnt shake alot, very nice! I havent tuned it yet or dyno'd it but soon.
Old Oct 2, 2004 | 04:34 AM
Grant B's Avatar
cyclerage,
Please let us know what the car ends up dynoing or running, as I need a no-maintenance setup.. Also, was your PtV loose enough to allow a thinner HG?
Old Oct 2, 2004 | 10:29 AM
NO CATZZ's Avatar
I installed this cam in my budies 99 Trans Am with .030 milled heads larger valves and 1.8 rockers. Absolutly not PTV issues whatsoever. Even untunned this cam screams and loves RPM.
Old Oct 2, 2004 | 03:43 PM
camaross383's Avatar
I'm about to sell mine, it's still in the car presently. It has about 200 miles on it. dynoed this morning, pulled 397/ 381
Old Oct 2, 2004 | 04:10 PM
Chris@AP-Engineering's Avatar
Under criminal investigation for fraud
You won't have any PTV clearance problems with the ASA cam and your set up.
By Brett Foote | 2026-06-04 05:00:17
