TSP 231/237 installed
Old Sep 10, 2004 | 09:25 PM
c5jonny's Avatar
Default TSP 231/237 installed
Just had my TSP 231/237 installed in my 99 C5 vert, along with ls6 intake, better flowing filter, UD pulley,and 160 thermo. Numbers before install were 306RWHP and 33?RWTQ. After install came out with 354RWHP and 370RWTQ. I had long tube headers, a 3500 stall converter and 3.73's. for both dynos. The car has really woken up, feels great, tune is awesome, it actually idles pretty nice. Not a lot of shake at all. Now I just need to get some new track #'s. I think ill finally reach my quest for 11's
Old Sep 10, 2004 | 09:28 PM
rons 00z's Avatar
i cant wait to get mine put in. those hp number seem odd though from what i've seen this cam makes way more hp than tq but in your case it seems to be opposite. have any graphs? also what dyno was it on mabey thats whats throwing me off. but still if it runs good thats all that matters
Old Sep 10, 2004 | 09:36 PM
lock down's Avatar
you had 306hp with long tubes? that pretty low for long tubes. Nice pick up after the can
Old Sep 10, 2004 | 09:43 PM
c5jonny's Avatar
yeah, 306 with long tubes 3.73s and 3500 stall converter. I was pretty much stock as far as intake goes. I dont have a scanner, but my TQ peaks at what appears to be right round 4100rpms, and HP #'s peak at 6400 RPM's. The HP looks like it would keep climbing if it werent for the rev limiter being set there.
Im not sure what kind of dyno it was, but my sheet says Winpep Dynojet performance evaluation program if that sheds any light.
Old Sep 10, 2004 | 10:40 PM
cyphur's Avatar
Still kinda low numbers for lt's. Glad your car woke up after the cam and ls6 intake. I'm going to have to get my car on a dyno before I do the swap so I have some before numbers, but after I get lt's, with the 231/237 I'm hopin to be somewhere around 400 to the rear wheels.
Old Sep 10, 2004 | 10:54 PM
c5jonny's Avatar
You should def. be close with the m6, let me know how you make out. BTW the thing sounds awesome at idle. Brings a smile to my face just thinking about it.
Old Sep 10, 2004 | 11:02 PM
cyphur's Avatar
Oh yea. I have to break in my brand new Spec 3 first. Had to replace the clutch for a very stupid reason, so I just went with the Spec 3. Grabs like a sonuvabitch....just gotta stay off the gas for a while. So I'm keepin the cam out til then. Also want to install headers same time as cam, cuz otherwise I'll be chokin her.
Old Sep 11, 2004 | 01:57 AM
Tranzor's Avatar
Not bad numbers at all for an A4 C5 vert... Glad you're happy with yours, I'm really happy with my 231/237 cam as well.
Old Sep 11, 2004 | 10:52 AM
speedo's Avatar
I have pretty much the same set up...no dyno numbers yet, maybe next week for the dyno and forsure the by weekend I will have some 1/8 mile times.
Did you have a tune???
If you do...., where do you and anyone else with this cam have the red line set. I think mine is around 6300. I think that is shy yet as the car is still pulling nice before the shift. I still have the stock 273's in so I am going to wait till I get them 3.73's in ( six months of being in back order and still no thick gear ) to see if that changes anything since I had the tuner tune it for them right away.
Old Sep 11, 2004 | 05:21 PM
LSUxBlake's Avatar
That cam seems like it would respond MUCH differently with a set of ported heads. A lot of larger cams wont perform as well with stock heads as a more conservative duration would.
Old Sep 11, 2004 | 05:44 PM
cyphur's Avatar
Well it doesn't help that he has an A4 C5 either. I didn't take that into consideration when I first posted. Between the A4 drivetrain loss and the IRS loss....yea, he'll end up lower then many. But that won't stop him from flyin down the 1/4 if he can hook.
Old Sep 21, 2004 | 10:20 AM
c5jonny's Avatar
Car shifts at 6200, redline is set at 6400
Old Sep 21, 2004 | 11:05 AM
Juiced's Avatar
good cam, just watch for valve float when reving it high the stock lifter don't like hi rpms
Old Sep 21, 2004 | 11:07 AM
Tranzor's Avatar
I've been racing a handful of times with this cam and haven't seen any valve float... I'm shifting around 6700 rpms and it's still pulling like a champ up there.
Old Sep 21, 2004 | 11:12 AM
c5jonny's Avatar
Yeah when my dyno graph cut off at around 63 or 6400, HP was still climbing steady. I have to get to the track!
Old Sep 21, 2004 | 11:16 AM
Tranzor's Avatar
Yep, this cam loves to live over 5500 rpms... makes a ton of power up in the upper rpm band. From about 3000 rpms on, that's when it really pushes me back in the seat when I floor it.
Old Sep 24, 2004 | 09:37 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Are you running the hardened pushrods? I would set that rev limiter at about 6800rpm!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Sep 24, 2004 | 10:35 AM
PREDATOR-Z's Avatar
They are the same lifters than a Z06 and those climb till 6800 all day long.
