Cam Is In But There Is A Problem????
Old Sep 11, 2004 | 12:23 AM
dddz06's Avatar
Default Cam Is In But There Is A Problem????
2001 ZO6
I Have A Comp Cam 228 / 230 .588 .591 112 918 Springs Stock Retainers PUSH RODS ARE TSP,7.4 LENGTH. I Started The Car Up An Ran It At 2000 Rpm For 5 To 10 Mins An Shut The Car Off For 10 Mins An Started Her Back Up An There Was A Nocking Noise On Both Sides Of The Heads Can Some One Thell Me What That Is Or How Can I Fix That The Car Only Has 9000 Miles On It. ARE MY PUSH RODS TO LONG OR THE ROCKERS TO LOSE HELP
Old Sep 11, 2004 | 12:26 AM
2xLS1's Avatar
Need more details. What procedure did you use to tighten the rockers? Did you mess with the oil pump when you installed the cam?
Old Sep 11, 2004 | 12:39 AM
dddz06's Avatar
I JUST PUT THEM ON AN TIGHTEN THEM DOWN THE OIL PUMP I JUST CHECK THE BOLTS TO SEE IF THEY WHERE TIGHT THAT'S ALL
Old Sep 11, 2004 | 12:43 AM
2xLS1's Avatar
Did you use a torque wrench. They need to be torqued to 23 ft lbs.
Old Sep 11, 2004 | 12:48 AM
dddz06's Avatar
No I Did Not I Tighten Them By Hand After I Ran The Car At 2000 Rpm An Shut It Off An Started Her Back Up There Was The Nocking Noise
Old Sep 11, 2004 | 12:51 AM
2xLS1's Avatar
Get a tq wrench and retighten them.
Old Sep 11, 2004 | 12:53 AM
dddz06's Avatar
So U Think That Might Be My Problem ?
Old Sep 11, 2004 | 12:59 AM
cyphur's Avatar
??? Pull the covers and find out. Get the tq wrench and see how tight they are.
Old Sep 11, 2004 | 01:02 AM
dddz06's Avatar
Ok I Will Let U All Know Tomorrow
Old Sep 11, 2004 | 07:07 PM
dddz06's Avatar
i use the tq wrench an it work that was my problem,thanks know my engine light is on what can that be
Old Sep 11, 2004 | 09:49 PM
badpewter-z's Avatar
LS1TECH Sponsor
most likely multiple missfire, a decent size cam will usally do that, once tuned out you will be fine, the computer sees what it tihinks is a misfire at idle and gives you the light
