rough idle
Old Sep 13, 2004 | 08:49 PM
01'WS6's Avatar
Default rough idle
I have a friend with a 99 SS and its idleing a little bit rough almost like a miss but not as bad or as steady. Anybody have any clue on what this could be? We checked the fire to the plugs and MAF and turned out not to be the problem so now we are stuck.
Old Sep 13, 2004 | 09:03 PM
JMBLOWNWS6's Avatar
Id say use some sea foam and do a top engine clean on it.
Old Sep 13, 2004 | 09:51 PM
Gloveperson's Avatar
Hows your fuel filter?
-Todd
Old Sep 13, 2004 | 11:10 PM
01'WS6's Avatar
just changed it a month ago.
Old Sep 13, 2004 | 11:20 PM
Is it throwing any codes?
-Todd
Old Sep 13, 2004 | 11:30 PM
'Trust''s Avatar
Get different plugs, some plugs idle rough some idle smooth,
Old Sep 13, 2004 | 11:50 PM
01'WS6's Avatar
no codes put ill try the some other plugs not real sure when they were changed last. its just a bitch to do w/stock manifolds still on there. thanks
Old Sep 13, 2004 | 11:52 PM
That is a bit of an understatement
Surprising you don't have any codes though.
-Todd
Old Sep 30, 2004 | 04:08 PM
mc01ta's Avatar
my car is an 01 trans am, and it is doing the same thing, no codes. Figure anything out?
Old Sep 30, 2004 | 04:13 PM
cyphur's Avatar
pull the connections on the battery and leave them off for 10-15 mins. then hook them back up. your car will run like **** for a min. let her idle, shut her off. start her back up, let her idle for a few minutes, then drive her around for a few minutes, no high rpm driving, just normal stuff(ie normal for OTHER types of cars....2-3k rpms....), then get on her a few times. what you're doing is having your car re-learn all its tables. hopefully this will help solve the problem while avoiding a plug swap. those can get aggrivating. if this doesn't help....check your sensors....then do the plugs/wires....
