AFR Independent Flow numbers inside
Old Sep 17, 2004 | 10:30 PM
bigdsz's Avatar
HumppinSS, those are Absolute Speed heads, not patriots. Flow and HP gain are good across midrange also.
I am not knocking the AFR's, the more new products out there the merrier for us. Edelbrock has a head offering in the works for us soon. This can only be good for the sport.
I think the AFR's will rule with FI because of the thick deck, however I don't think the porters a going to be able to do anything earth shattering with the AFR's that they can't already do with other castings.
Also the slow release of these heads with promise after promise month after month has become a little anti-climactic.
Old Sep 17, 2004 | 10:38 PM
MUSTANGEATER's Avatar
AFR is a pretty good product. The only bad things I have heard is about the cooling passages, and the fact they get a lil pissed when you call them and up and ask for the heads w/o seats or guides
Old Sep 17, 2004 | 10:50 PM
HumpinSS's Avatar
Its a new product be happy they didnt release **** just to have it rushed to the market...
I am all for waiting because I beleive these heads will perform. They have allready released a 205 cc runner that flows 300 cfm. Most aftermarket runners are well beyond 205 cc and the integrity of the head has been compromised. Along with less P to V clearance and a shallower deck. my money is on the 205's for the street and i am pretty sure with a runner size of 225 cc it will be COMPARABLE if not EXCEED what we have on the market today....
Old Sep 18, 2004 | 01:38 AM
Justin99TA's Avatar
We will see. A local guy is getting them and I'll run him. I really doubt he will see gains that are worth $1000. I almost did jump on this bandwagon but couldn't see spending the extra cash. I guess only time will tell. We have the same setup except heads. If they perform so much greater, I will buy a set but if its only a tenth or so faster then my car is now, screw that. I can think of much better things to spend my cash on.
Old Sep 18, 2004 | 02:46 AM
PREDATOR-Z's Avatar
It doesn't matter whether you're beaten by an inch or a mile, the fact remains YOU ARE BEATEN.
Old Sep 18, 2004 | 08:12 AM
66deuce's Avatar
flow numbers don't tell the whole story.you can have a head that flows 280cfm and make more power than a head that flows 300cfm.the enviroment inside an engine is a lot different than a flow bench.there are a lot of dynamics that will affect flow that you can't duplicate on a flow bench.reversion is one thing that comes to mind,especially with a cam that has a lot of overlap.that's why on a nextel cup car they will use different port designs for different tracks,depending on where they need their powerband to be.from what i've seen on the board here the AFRs are a great head,with good mid-lift flow and small ports.that's what you want in a street strip car.
Old Sep 18, 2004 | 08:52 AM
SAM98WS6's Avatar
Originally Posted by jrp
guys, you can spout off you "higher" flow numbers over the AFR's but your not looking at the whole picture. Ryan is the pefect example, his PP 5.3's heads get there *** kicked by mikey's (rapid motors) 5.7 stg 2 heads with stock compression in under the curve power. same cam, mods, and tuning.
Thats exactly why I have Rapids Stage 2 LS1 heads. For that amount of money I would have chosen Rapid LS6 heads. Good luck with the AFRs..I hope they work as advertised.
Old Sep 18, 2004 | 09:32 AM
max's dad's Avatar
For that amount of money +200, +1200 core, +sales tax if you live in PA
Otherwise, I would have gone that route as well.
Old Sep 18, 2004 | 10:56 AM
mikey's Avatar
LS1TECH Sponsor
You absolutely cannot say that a particular head will perform better simply based on flow numbers. Flow is a very small part of the equation. Port volume, velocity, swirl, tumble and turbulence are all part of the deal. When we developed our port, it was done to maximize the area under the curve and not for flow. A world famous super stock engine builder did our port design and he stressed turbulence as the number 1 killer of power. He said that not too many head folks know what to "listen" for. He showed me two different ports on the flow bench (ours and a competitors) where one port actually produced more peak flow but was "noisy". I could not tell the difference in noise between the two but sure enough when they were both tested, ours produced more power all over with the same cam and header package.
Bottom line is that you cannot judge a head based on flow alone. AFR is known as a reputable company and I would not hesitate to look at them.
Mikey
Old Sep 18, 2004 | 11:22 AM
Hysteria's Avatar
I agree with both 66duece and mikey. That may explain why my car dynoed simular as a few hot cam cars with professionally done heads. But then again the hot cam is more taylored to stock headed cars.
Old Sep 18, 2004 | 11:30 AM
LS1derfull's Avatar
Mikey
I can agree with this post completely, the turbulence and noise is very distinctive with LS heads. The efficiency of these port designs really activates a much larger portion of the port, compared to older traditional style heads. These LS1 ports are on the fine line of too much swirl,and tumble, which affects flow as turbulence. This is the result of port design mixing in all these ingredients to get the most atomization for more complete combustion. Getting max flow and power is usually done by changing port to manage these effects better to allow more uniform airflow, this can be heard on the flowbench. I have found airstreams in a single port cancelling each other out causing flow stagnation at certain lifts. Introducing objects into the port can alter this condition and allow much higher flow numbers and cleaner sound thru port. LS1 is very complex ,focus on just flow numbers or port volume is too one dimensional. Least resistance to cylinder filling at critical piston position is smart way to analyze head potential.
Old Sep 18, 2004 | 03:54 PM
  #32
galopin's Avatar
Default What's That Sound?
I was talking to the guy at WeldTech about minimum cross section and velocity and one thing he mentioned was that high-velocity cylinder heads are quieter when flowed on a flowbench than cylinder heads with less velocity. Has anyone else noticed this?
Old Sep 19, 2004 | 04:06 AM
  #33
Justin99TA's Avatar
That tenth is easily made up with more juice so in a sense I would still be money ahead. If someone is a tenth faster then me motor v motor but spray v spray I get them, then I wouldn't be getting owned. I guess the bottome line is I don't see a tenth or 2 mph worth $1000. If my car would go from trapping 118na to 125 na by bolting these heads on then they would be worth it to me. Right now I will stick with my cheapo pp 5.3 heads until these are proven. I know AFR makes a good product but until they out perform to a degree that is worth the extra $1000 I wouldn't buy them. The local guy is getting the 225s so we will see. When I was looking into heads before I was told by speed inc that you did not want 225s for stock cubes and that is what he has? Please explain
Old Sep 19, 2004 | 04:19 AM
  #34
jrp's Avatar
jrp
SN95 Director
and how do you know your PP arent 225 cc on intake, did you have yours measured? the old PP 'ls6' style heads were advertised @ 225 cc but alot of them measured @ 230+. who's to say your "215cc" 5.3's arent bigger. just like you dont know what yours flow.
the AFR 225's should they pan out to be everything as advertised should be badass; stock cubes or not. most ls1 ported castings end up being 230+cc so maybe you misunderstood what speed inc told you.
Old Sep 19, 2004 | 05:43 AM
  #35
PREDATOR-Z's Avatar
Please read the below carefully. This is from the mouth of the tiger himself. No second hand, hear say.
Originally Posted by Tony Mamo@AFR
The biggest thing that bothers me is all of you guys are missing the boat on the entire CONCEPT the 205's are based on. It was designed to be a great all around STREET head with the potential to improve fuel economy, reduce emissions, enhance throttle response and drivability, and still provide GREAT ALL AROUND POWER. Based on results we have compiled, I would be the first to admit that a 205 would probably show a 10-30 HP advantage over most "Stage II" ported castings, while still providing the other benefits noted above (in addition to the beefier casting quality). Documented in part of our emissions testing was the fact that the AFR equipped car produced 20+ additional RWHP, less emissions gases, and an increase in fuel efficiency of 1.5 MPG. This was over a bonestock Z06 with no other modifications whatsoever. Needless to say, we passed with flying colors...
As some others have pointed out....Is a swap to AFR 205's a "cost effective" move if you already have a good set of ported factory castings? NOOOOOO!!!
If you don't care about cost effectiveness will it help improve OVERALL PERFORMANCE....YEEEEES....In most cases I BELIEVE that to be true.
I have more to say but will save it for another day....the last thought I will leave you with is the engineering department is currently working on digitizing the new AFR 225.....In my opinion, the 225 will be the ultimate head for guys looking to make BIG power in a stock displacement shortblock (and of course you stroker guys as well) and put an even larger gap on most of the competition, our own 205's included. The 225 head will make a swap from ported fatcory castings a much more cost effective mod.
Now AFR will be on a level playing field as most ported factory castings are 230 cc's or greater
Now is this clearer to you??
Old Sep 19, 2004 | 07:43 AM
  #36
HumpinSS's Avatar
We need a picture of the dead horse getting beat. There are those that understand and then others that are clueless
Old Sep 19, 2004 | 10:12 AM
  #37
SAM98WS6's Avatar
I would like someone to help me believe this: (AFR quote above)
"I would be the first to admit that a 205 would probably show a 10-30 HP advantage over most "Stage II" ported castings"
then the horse will be dead....
I just think the gap is getting narrower for improvement..aftermarket heads over old time chevy..big gap for improvement...aftermarket head over LT1...smaller gap...aftermarket head over LS1....small gap.... I cant be a blind follower...
Old Sep 19, 2004 | 10:38 AM
  #38
PREDATOR-Z's Avatar
What is your point????
Old Sep 19, 2004 | 11:36 AM
  #39
Justin99TA's Avatar
This is totaly different from what I was told lst January when I was looking into
buying heads. If they are that great I will buy a set but if not I dont' see the point
Old Sep 19, 2004 | 12:39 PM
  #40
SAM98WS6's Avatar
exactly...
remember the first post in this thread showed "averagish" independant flow numbers...we are all just giving our opinions...
show me....
