AFR Independent Flow numbers inside
Advertised Numbers Independent #'s
Int Exh Int Exh
.200 140 112 138 112
.300 200 170 208 168
.400 251 203 251 199
.500 281 221 285 225
.550 292 226 na na
.600 301 230 290 226
I guess you get what you pay for when you go with a reputable company.
for anyone that is confused the 2nd set of numbers are the independent ones
Oh yeah the heads are going on tonight
The AFR's do look awesome...
Good luck..
--------Advertised Numbers--------Independent #'s
---------Int-----Exh----------------Int----Exh
.200____140____112______________138___112
.300____200____170______________208___168
.400____251____203______________251___199
.500____281____221______________285___225
.550____292____226______________na_____na
.600____301____230______________290___226
Flow + velocity = a good thing
On the bench I know a set were tested on, they cam e in spot on with what AFR reported.
Sam... I went with AFR for a few reasons
1. 205 intake runner...I like the idea of the higher velocity port
2. The AFR head leaves me room to expand in the future if I ever go larger than 347
3. AFR is a reputable company that stands behind there product
Sam you are also basing your opinion on advertised numbers. In addtion a lot of sponsors on this board are not running anywhere near a 205cc Intake runner
I am very happy with my choice I will post my numbers after the install
The flow numbers I've seen on their CNC heads are usually within a few cfm from what I get on my bench.
The single best 23 degree Small Block Chevy head that's ever been on my bench was an AFR 227. Enough said about AFR's ability to design a head in my book.
I plan on getting a set of the 225's when they're available. I'm anxious to see what they'll do compared with the standard Chevy LS6. I'm thinking they'll be a lot better, especially up at high lift. The Chevy head has some thin areas where we need for them to be thick. That places severe limitations on a head porters ability to get them to flow smooth above .600 lift.
Josh
Uneducated to say the least. what was the runner volume of those patriots? Answer that question and you will see why the AFR's are the ****? And their -6cc flowing heads will walk your 1K heads in a heartbeat. YOu get what you pay for and all you paid for was a few peak numbers....
