tr 224/224 owners step inside
Old Sep 22, 2004 | 03:16 PM
whitecamaross's Avatar
ok i see that, but is it because of the lift on that cam? would a trex cam trap higher than the tsp cam??
Old Sep 22, 2004 | 03:32 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
It's not just lift, it's many factors. Yes, a TRex will trap higher than a 231/237.
I've seen a few 120+ mph, cam-only TRex threads here.
Old Sep 22, 2004 | 03:58 PM
where is your rev limiter set up? where do you shift at??
Old Sep 22, 2004 | 03:59 PM
!LS1 11 Second Club
Limit @ 6900 rpms. Shift light comes on @ 6600 rpms.
Old Sep 22, 2004 | 04:04 PM
jesus..6900??? dont they say that it is bad to rev up that high for the motor? how long can your motor hold if you keep shifting close to the 7k mark? i think my cam peaks at 6600rpm so i am planning on setting the rev limiter at 6700. where you there at kelly's when they tuned your car?
Old Sep 22, 2004 | 04:08 PM
!LS1 11 Second Club
Many people are revving up to 7k on stock bottom end. It may not be the best thing long term, but that's what's being done- especially with the larger cams, 'cause that's where the power is being made.
No, I wasn't there for the tune session.
Old Sep 22, 2004 | 04:14 PM
did u ever post your dyno sheet?what were your actual dyno numbers?
Old Sep 22, 2004 | 04:17 PM
!LS1 11 Second Club
Never posted the sheet. 425/387
Old Sep 22, 2004 | 04:22 PM
!LS1 11 Second Club
Here it is. Didn't post it, 'cause the printout range isn't useful.
Old Sep 22, 2004 | 04:24 PM
man ill be lucky if i put down 375-380 rwhp on monday. with a mid size cam like mine i think that 370s is more like it. i was 2 seconds away from buying that tsp 231/237 before i got the tr 224/224 cam. not i am unhappy with it, but i street race alot more so i could have benefited from a higher mph than the one i have. i could buy another cam like you did, but man i really dont want to take that whole motor apart again. jesus, that is just too much work to do all over. specially dropping another lifter. hell no, although i am still looking to buy mti stage 2 heads and thats the only way i would upgrade to a bigger cam.
Old Sep 22, 2004 | 04:31 PM
!LS1 11 Second Club
Actually, for street racing from a dig, the TR224 is better. The 231/237 shines up top, but has a peaky powerband compared to the TR224.
Old Sep 22, 2004 | 07:32 PM
  #32
AKRA's Avatar
I have the Lunati 224/224 560/560 112lsa and my cam peaks it's HP at 6300 rpm's. I also have the patriot heads but my peak hp is 400 and my peak torque is 375 ft-lbs. If I remember correctly the TR cam has a little more agressive ramp rate.
Good luck,
Al
Old Sep 22, 2004 | 07:49 PM
  #33
Kurt D's Avatar
My friend's m6 T/A has a TR224 on a 112 lsa in it. He dynoed 385 rwhp and usually traps between 112-114 on street tires, i.e. 2.1+ 60fts. He also has the usual bolt-ons: lid, ftra, GMAF (pos), LS6 intake, LT w/ cats, catback, etc. He was also running the stock 3.42 gears and full weight.
Old Sep 22, 2004 | 08:29 PM
  #34
DEEZ98Z's Avatar
I have an auto... but my car made 373/373 with a locked converter.... my car usually traps around 113... my best was 113.9
Old Sep 22, 2004 | 08:44 PM
  #35
TNTramair's Avatar
lol...my friend with absolute heads and g5x3 cam shifts at 7k on a stock bottom end...personally i think hes nuts, but hey, hes gotta be doin something right for 610rwhp<--- with a 150shot also..
Old Sep 23, 2004 | 05:17 AM
  #36
DownUnder's Avatar
I have a TR-224 112 and on stock gears in a manual of 3.46 also with .020" off the heads ran 113.90mph. Thats in a car weighing around 3650 pounds with me in it. It peaked on the dyno at 5800 and limiter is set at 6350.
Old Sep 23, 2004 | 09:57 AM
  #37
z98's Avatar
z98
the tsp 231/237 traps alot higher for some reason.
Um, because its a lot bigger cam?
Old Sep 24, 2004 | 07:57 AM
  #38
mc01ta's Avatar
who makes the TR 224 (dumb question I know) I have an 01 TA M6 and I'm thinking about going with this cam based on what I'm hearing. I have lid, tb, catback, free mods and thats it. I want a mild streetable cam that is a notch or two above stock. Besides the cam what parts are needed. Someone give me price on the cam and everything I need to go with it please. I don't really plan on doing head work in the future.
Old Sep 24, 2004 | 08:01 AM
  #39
!LS1 11 Second Club
^ Thunder Racing (Sponsor) ------>
You need valve springs (Comp 918's will be fine). Hardened pushrods highly recommended, titanium retainers would be nice, but stockers are OK.
Check out the cam swap info at ls1howto.com
Old Sep 24, 2004 | 09:12 AM
  #40
1fastWS6's Avatar
That TR224/112 peaks at more like 5800 not 6600. Mine on a 114 lsa peaked at 6000 and I shifted it at 6400-6500.
