Help. Engine tick.
The ticking was/is still there after the stock rockers were re-installed. I've put a few thousand miles on it and the tick is driving me nuts. Tonight, I did the "put a long screwdriver on the valve cover" trick and didn't hear anything. I put my screwdriver on the exhaust manifold and sure enough, there was a very loud tick. I'm about 70% sure I have an exhaust leak between the manifold and cat. Do you think I'm hearing an exhaust leak? If not, should I just tear the motor apart and replace the lifters (I've already re-torqued the rockers to 22ft lbs)?
HATE IT! iv never replaced just thr oring i always do the lifters with it because the vehicles i work on are under warranty but after i do the repair the noise is gone but i dont know if it was the lifters or the o-ring i think gm wants the o-ring first cause its cheaper?
We were having a problem with my car getting some nasty valvetrain noise. We rechecked the valvetrain 3-4 times, and everything checked out just how it should of been. The last time it was put together, we used a little thread sealer on it and it was 10x better. I'm not saying this will fix your problem, but it's something else you could try.
Got a video of the sound it's making? That might help us help you.
The video is hard to see and hard to hear so it might have been a wasted effort. I can hear the tick in the video but it's very faint. In person, it's obnoxious.
Since it's hard to hear, here is a timeline of it....
Video starts with me in the driver's seat. I got out and put the camcorder on the ground behind the front tire. Then I popped the hood and put the camcorder on the right side of the engine bay, then the left.
The ticking is loudest behind the driver's rear tire and above the driver's valvecover/manifold. Like I said, it can be heard if you put a screwdriver on the driver's exhaust manifold but NOT the valvecover.
TIA.
http://www.gysoms.com/tech/tick.wmv
What part of the valvetrain are you using thread sealer on to quiet it down? This built block is a noisey biatch.
I would lean toward a bent pushrod or a bad lifter if the tick is pretty bad. It was hard to hear over the background noise.
I've tried two sets of pushrods. I'll pull that head off and replace the lifters. Should have done that when I had the head off last time.
