p.p valve springs
Old Sep 29, 2004 | 03:36 PM
chino_man279's Avatar
What are the specs on the older(non gold) Patriot springs? Pressure? Max lift? Coil bind?
He was running a pretty small cam(relatively)....
Old Sep 29, 2004 | 08:52 PM
WS-6_2002's Avatar
How do you know when you've broke a valve spring? I got a wierd ticking noise coming from the top half. As the RPMs rise and car warms up the noise gets louder and faster. I don't notice a drop in oil pressure. Car seems to idle ok.
Old Sep 29, 2004 | 10:26 PM
jrp's Avatar
jrp
SN95 Director
this is what the PP golds look like, there off my heads (non PP). i've used Rev and manley, and have seen 918's and lunati springs and these are bar none the best i've seen.
http://ourworld.cs.com/jrp98ls1/DSC00408.JPG
http://ourworld.cs.com/jrp98ls1/DSC00410.JPG
Old Sep 29, 2004 | 10:47 PM
dvandentop's Avatar
Old Sep 29, 2004 | 11:25 PM
Sn8ke_Eater's Avatar
Originally Posted by GUNNAR@PATRIOT
Kinda like a grayish-brown. I guess that's the best way to describe it. If you have seen one of our golds, you will defintely be able to tell them apart.
Yes gunnar was right i was wrong i tought it was a gold valve spring but it ended up being a bronze color.those were the first springs that they came out with.Sorry to p.p. thinking t was a gold spring.But gunnar at p.p took care of me anyways by sending be there best springs wich are the gold double springs which i have heard pretty good about thanks gunnar for taking care of me.
Old Sep 30, 2004 | 01:15 AM
Cobraeater's Avatar
Talking
It's all good man!
Old Oct 7, 2004 | 09:21 AM
chris2000ss's Avatar
i'm happy to hear it wasnt a gold!!!!! I just installed a set last week!!!
Old Oct 8, 2004 | 07:18 AM
99Fbody99's Avatar
For what its worth I am running the golds to 7k rpm with and install height of
1.740"!!
With the cam lift it puts it just past the .650" max lift recommended.
1000 miles, a few track days, hand full of missed shifts and no spring issues.
Based on past experience these are truely top notch.
Dave
Old Oct 8, 2004 | 12:43 PM
NA$TY-TA's Avatar
This is not the first PP gold to break.......... I run them myself with a 230/236 .598/.608 cam and my buddy who broke 3 of them broke them with his TSP 231/237 cam.........
Old Oct 8, 2004 | 12:55 PM
Cobraeater's Avatar
Arrow
Did you even read this thread?
Snake Eater had the non-gold patriot springs, and you're friend Nakoz with the 231/237 cam who broke 4 of them (not 3) was using the factory valve spring seats when he should have used the valve spring seats that come with the patriot kit.
We all been through this before.
Here's the threads.
https://ls1tech.com/forums/showthrea...t+gold+springs
https://ls1tech.com/forums/showthrea...=gold+breaking
https://ls1tech.com/forums/showthrea...ighlight=Nakoz
There have been ZERO cases of Patriot Golds breaking!
PREDATOR-Z's Avatar
At one time or on separate occasions?
Seems weird to me, if at one time, that would be a definite indication of bad install tolerences.
