Cam advice? Split, reverse split or equal?
Old Oct 19, 2004 | 01:38 PM
  #261
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Originally Posted by mrr23
i know there's more to life than .050 but none of those cams have any reverse in them at all. except for the one with opposite lift. and the reason for that was because of how aggressive the ramp is. that's the only reason.
i don't expect you to give a cam away. but it looks like somebody can't call you and discuss one either. because you would have to talk specs. and you don't give specs out for free.
Again, "none of those cams"... Understand that its all the same camshaft. Its only one cam, not 3 cams. I'm citing duration at three points on the same cam. Its a positive split cam at .006, its a symetric cam @ .050, and its a reverse split @ .200. What I'm trying to point out is that you have artificially limited yourself by looking at only one point on the cam. You have also limited yourself by by looking at one dyno graph and calling it gospel.
I've never turned anyone away from discussing cams. I have spoken via PM and email NUMEROUS times. I'm just saying I'm not going to post the complete specs on a cam in a public forum. If you buy a cam, you get a cam card, etc... You just don't get it for free.
Old Oct 19, 2004 | 01:50 PM
  #262
mrr23's Avatar
Originally Posted by SportSide 5.3
I think, relatively speaking its easier to focus on than application if you narrow it down into a category. For example, .050. Everyone uses it, and some make a purchase just off of those specs without looking at anything else. What I'd like to focus in more on is valve events.
Mrr23, do you know--
Based off what, is how Vinci chooses his ve's? Any principals or understandings he follows? I've learned a few, mainly from Shaun because he's one of few who have been open with how they do things.
I think if you looked deaper into alot of the cam's being sold here, they wouldn't show much difference. The biggest difference would be the name of the cam.
honestly, you'd have to call and talk to roger on how he chooses VEs. i can't answer that one. he'll be more than happy to discuss cam profiles with you.
Old Oct 19, 2004 | 02:00 PM
  #263
mrr23's Avatar
i understand. you are only protecting your interests on not posting cam specs in a public area. and i respect that. as far as calling things gospel. if that's all the information i have, then i draw my conclusions from the information presented to me. i have been waiting for others to post their results showing where a reverse split has made a positive difference below 5500 rpms.
just like sportside 5.3 said, we only get specs listed to us at .004 or .006 and .050. and that's where all these terms of reverse split, single pattern, and standard split come from.
when you see specs like this:
280/280 @ .006 230/230 @.050 on your cam card, guess what? you would call it a single pattern cam. do you agree?
272/280 @ .004 210/218 @ .050 on your cam card, you'd call this a standard split. correct?
then you have the exceptions to the rule. like your cams and those like you posted. depending on the point you look at, it can classifed as all three.
question for you. when you give your cam card out when you make a cam, does it have duration at all lift points? say .006, .050, .100, .200, .300, .400, .500, etc?
i am glad you and others are here to show people there is more to a cam other than .006 and .050. but, the industry made it the standard. now, we have to convince the industry to change it.
Old Oct 19, 2004 | 02:09 PM
  #264
mrr23's Avatar
Ummmm hello they are al the same cam... I was showing how the same cam depending on what point on the lobe you decide to look at can be positive, symetric, or reverse.
um hello back at you. i was refering to the cams i posted. not you one cam at different lobe points.
I don't think anyone is against discussing general parameters on a cam. The thing you will find is that since you narrow your view to only duration @ .050 that much of the "magic" that happens behind the scenes on cams would be lost on you. Also, since you have made it fairly clear that you can't and won't get past duration @ .050 determining that a cam is positive, symetric, or reverse talking about you lobe lift and duration eleswhere would be a waste. The other practical matter is that if someone publically posts cam specs then anyone can try (and I do stress try) to copy those specs. Then they chime in on how the cam doesn't work even though it isn't the right cam for their combo.
and when i asked you and EDC to spec me a cam, i wasn't looking for all points. the .006 and .050 would've been sufficuent for this thread. because again, that's what the industry has set the parameters at. you blame me for what the industry set the standard at.
Here is the deal cam specs don't get given out for free. Its just that simple. But, general things can be discussed. But, most cam guys aren't going to publically give you lift and duration at all the points, and valve events just so anyonecan go copy it... Its simple if folks want a cam they have to pay for it.
And, there are plenty of "non-box" grinds for stock headed cars out there that have been done. I haven't heard any complaints yet on them.
no problem. understood. and there has been plenty of 'box' grind cams out there that haven't had any complaints on either. back in the early 90s, my first cam was the comp cam 280H. i didn't complain a bit about it. i was going quicker with it, a 650DP, and PERFORMER RPM intake over another guy with the same car that had the 292H, 750 DP, and victor jr intake. i had 3.42 gears. he had 4.10 gears. man was he pissed.
Old Oct 19, 2004 | 03:00 PM
  #265
Cstraub's Avatar
Doesn't matter wether the cam is symetrical, asymetrical, reverse, standard, single pattern, single-reverse-single. .. what matters is the cam accomplishes the goals set by the customer. I have NEVER gone into a project thinking it has to be this way.
True story, a customer of mine in IA had a blower engine to do for a hurry up grudge street race (I DO NOT AGREE WITH THAT TYPE OF RACING) using a BBC. The heads were through togethers, terrible with a 10-71. Due to CID and exhaust flow inthe 50% range, I ended up with a cam with 28 degrees more on the exhaust. I have never seen a cam so crutched. . . .Well long story short, car won, engine ran like a raped ape and according to the customer better then his $25K bullet that had lost a rod some weeks prior. Moral of the story. . .it's not what you got, its the combination of the GOT!!
Chris
Old Oct 19, 2004 | 05:51 PM
  #266
mrr23's Avatar
good deal.
Old Oct 19, 2004 | 05:54 PM
  #267
Cstraub's Avatar
I bet V8er never thought this post would have this much action.
Chris
Old Oct 19, 2004 | 06:12 PM
  #268
Sport Side's Avatar
Whats the deal with JRP's low 70% range exhaust-intake ratio threw the mid-lift section?
Could the head porting play a part in this?
Old Oct 20, 2004 | 05:32 PM
  #269
Cstraub's Avatar
Hey Ed,
I guess after 6 years the day has come. . .Curtis VS Straub. . .so what will it be, average power over the curve or peak numbers?
Prize; Hmm dinner at St. Elmo's during PRI? That work?
Chris
Old Oct 20, 2004 | 05:52 PM
  #270
Sport Side's Avatar
Originally Posted by Cstraub
Hey Ed,
Chris
Whats going on?
Old Oct 20, 2004 | 06:20 PM
  #271
Cstraub's Avatar
One customer and a cam from each of us.
Chris
Old Oct 20, 2004 | 07:00 PM
  #272
Sport Side's Avatar
what combination is the test sample?
Old Oct 21, 2004 | 02:13 AM
  #273
NLang's Avatar
With a custom grind, say 236* @ .050, no two cams for different combo's should be exact @ all lifts. If this is the case, when ordering a custom grind, why would you choose a cam with a certain duration @ .050 lift? How on earth do you choose a starting point? Would it be .050 just because it's 'the norm'?
I have a 236/242-112 (@.050) custom solid cam that was ground for my last combo-75mm intake system/3" single exhaust/heads were only 71% intake to exhaust.
Now I'm @ a true 90mm intake system (yes, even the MAF)/3" dual X system w/ stepped LT's/12.25:1 SCR. I was recommended a 236/236-112 for this combo because of my extra free exhaust system. *BUT*, my new heads are barely @ 73-74% intake to exhaust flow. Would I not still need some crutching for the exhaust? The exhaust system is only going to flow what the heads will give it-common sense. If I over-scavange by giving it too much exhaust duration, what sort of drawbacks would I be looking at? Torque loss? BTW, Comp has nothing between 236/236, and 236/242 in 'street' solid form-go figure...
I've been through three cam techy's (custom cam vendors) and none of the three cared to let me pick their brains. They all gave me a 'that's just what you need'-not much sincerity. For what I've spent so far on this last project, that aint good enough...Any one of you few that are very experienced care to help a fellow gear-head out? This is the last grind I'll be doing for a while so I'm scraping for perfect...
Old Oct 21, 2004 | 07:09 AM
  #274
Ed Curtis's Avatar
Talking
Hey Ed,
Chris
CS,
Well, to be "really" fair, I better send "the project" a race cam and you need to send a dual purpose cam...
As for the bet, I'm game but it can't be PRI. With all that's happened this summer, it looks like a no-go for me this year.
NoseUp:
I'll have to side with the Cam Tech's that you spoke to. Good information is not free, nor should it ever be. There's a boatload of "Desktop Dyno" information available from any forum, including this one, but I for one don't race fantasy video games! As always in life, you get what you pay for.
I'd be more than happy to dole out some FREE pertinant camshaft data to anyone that can provide me with positively accurate IRS legal advice as well as some big money-making financial information for the same fee! FREE!
As in any venture, good advice/information comes at a price!
Ed
Old Oct 21, 2004 | 07:59 AM
  #275
Cstraub's Avatar
EDC,
Thats fair.
Nose,
Look up J-rods 2 x camshaft discussion post and then Denzss discussion on CFM, get a bag a chips and a tall glass of something and read. After that, if you don't have a good grasp on cams then I don't know what else to do.
Chris
Old Oct 21, 2004 | 05:08 PM
  #276
Cstraub's Avatar
Hey Ed,
Is the stock GTO cam a reverse split at .050"?
Chris
Just asking because you are the proud owner and someone posted these specs. . .
http://www.ls1gto.com/forums/showthread.php?t=8210
Old Oct 21, 2004 | 06:22 PM
  #277
Ed Curtis's Avatar
Talking
Hey Ed,
Chris
Don't know yet...
When I rip into this thing I'll "doctor" it and see what it is....
I'll probably get a Jesel belt drive to make all the cam swaps this thing will get a lot easier!
Ed
Old Oct 21, 2004 | 10:58 PM
  #278
critter's Avatar
Critter, you wouldn't happen to have any sound clips now would you?
OK, here ya go. The only pass on Sunday - I broke the 5/6 shift fork on this pass - 11.82 @ 90
I don't know if you can hear what you want or not.
Old Oct 22, 2004 | 12:33 AM
  #279
NLang's Avatar
Originally Posted by EDC
CS,
NoseUp:
Ed
I've DD'd the hell out of my combo. It's just as you said though, fantasy...All it seems to show is 'bigger is better'. The results completely contradict Comp's last recommendation. It's showing a 238/242-111 as my 'need' to get where I want to be. I'm tired of the guess and check game...I need some hard facts.
I've been through the cam thread, but perhaps I should swim through it again. Cams just aren't my strongest point...For every 'right' answer, there always seems to be another educated party contradicting it.
Old Oct 22, 2004 | 05:02 AM
  #280
Sport Side's Avatar
Critter.
i couldn't get it to work
thats ok, i just wanted to see how a 232 on a 109 stacks up to some of these other cams in idle characteristics. possibly better? b/c of good ve's...curious
